D17 S1 headlight boss thread
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Topic: D17 S1 headlight boss thread
    Posted: 30 Mar 2015 at 12:56pm
what the helms thread is in the headlight bosses?  I am trying to fit a set of aftermarket headlights to the front of my '59 D17 and can't seem to finger out what thread it is.  I tried 1/2" fine, coarse and even found a 1/2" hollow lamp nipple.  Can't get any of them started.  It looks like 1/2" fine thread, but the bolt won't go in and I don't want to screw up the threads.  It would be nice to have a hollow bolt to run the wires thru, but first I need to find what the threads are.
Anyone run into this?
cheers,
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 2:08pm
I'm not positive about a D17, but all of the B,C & CA's I've worked on were 1/2" coarse. It just may be that your threads are a bit too rusty. I usually use a tap first before I'll put in headlights, that also helps to make a good ground. The other possibility might be you after market lights are metric thread.
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 4:26pm
They should be 1/2 inch fine thread.  Just got done with 2 sets of lights and the front cowling and they were all 1/2 inch fine thread.  Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 4:58pm
thanks for the tip, it did look like fine thread, maybe only the smaller or older tractors use the coarse.   I'll run a 1/2" fine tap thru there and clean the threads up.  My aftermarket headlights have 3/8" bolts, so I'll just replace them with 1/2" fine.  Have to figure out a way to drill them out for the power wire though.
cheers,
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 7:24pm
I did mine for the C in my drill press.  Start with a small bit and get bigger as you go.  Try and get as close to the middle as you can!  Use a center punch and then drill.  Also chamfer the ends so the wire won't wear.  Worked like a charm.  I had to drill 3 as one was a little too far off.  I got in a hurry and went too big right away.
BradRisen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradRisen Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 9:01pm
If you have access to a metal turning Lathe ,makes it real easy to drill perfect, Dead center Holes in bolts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2015 at 3:06pm
I think I can get a machinist at work to chuck a couple bolts up in a lathe and drill them out.  Prob cost me a Snickers bar.  King size if he has to find the bolts.
Creek
