D17 Rear Axle Bearings |
shanajn ![]() Bronze Level ![]() Joined: 22 Jul 2015 Location: Illinois Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Jul 2015 at 9:46pm |
I am attempting to replace the rear axle bearings in my D17. I have the snap ring off and the retaining bolt loose, however, I can not get the axle shaft to move. I think the inner bearing is stuck on the shaft. Any tricks to remove / Drive the axle shaft out? Thanks in advance
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21914 |
Longer bolt threaed into the axle....bottle jack on its side with the pump down to press it out.
