D-17 piston pump |
mruhlig77
Joined: 19 Aug 2014 Location: central Indiana Points: 595 |
Topic: D-17 piston pumpPosted: 29 May 2017 at 9:31am |
Is there a good way to check one out..?.lift arms won't lift...fluid levels all correct....thinking of removing covers , draining, and new fluid....might have a stuck spring or relief valve??
Transport valve screwed out... Thanks, Mark |
Clay
Joined: 11 Sep 2009 Location: Udall, Kansas Points: 10166 |
Posted: 29 May 2017 at 9:36am |
Check the transmission oil level.
If it is high, there is a good possibility that the internal hose broke. |
Clay
Posted: 29 May 2017 at 9:37am |
I re-read the original post.
Check the linkage for the Traction Booster.
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 29 May 2017 at 12:13pm |
Check the pressure with a pressure gauge. Should be over 3000 psi
Good Luck! Bill Long
Edited by Bill Long - 29 May 2017 at 12:14pm |
mruhlig77
Posted: 30 May 2017 at 9:34am |
Any chance the cam lobes are wore out..?
Posted: 30 May 2017 at 10:19am |
Probably not the cam lobes as much as the rollers on the pumping arms. As long as you are FULL of hydraulic oil ( dipstick below fuel tank on right side of tractor with breather on the top of it) you about have to remove the pump for repairs if the pressure at the remote outlet isn't at least 3,000 psi. |
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1289 |
Posted: 30 May 2017 at 10:29am |
Blown lift arm hose.
Posted: 30 May 2017 at 10:45am |
If that is true, then the hydraulic compartment will be very low on oil and the transmission (to the right of the gearshift) will be overfull. He claims all THREE fluid levels are fine.
Brian Jasper co. Ia
Posted: 30 May 2017 at 1:41pm |
I had this same problem with my CA. It turned out the springs under the plungers in the pump had all broken so the plungers weren't following the rollers. 4 new springs problem solved.
mruhlig77
Posted: 31 May 2017 at 7:06am |
Thanks Brian and all...Mark
