D17 IV
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Topic: D17 IV
    Posted: 13 Aug 2017 at 8:18am
Just got a D17 ser IV that had been sitting for some time.  Lift arms will not come down even with weight on them.  You can see that it wants to lift but then does not release.  Any thoughts on what to look for.  Thanks
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2017 at 8:22am
The traction booster linkage is seized up with rust just ahead of the valve body.  Take is apart, clean and oil everything up and you should not have any problems.  A common problem for tractors this age (especially when they sit outside).
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2017 at 8:25am
Look at the traction booster valve linkage, somebody probably moved the lever to the max position and the linkage stuck holding the valve in. so spray your favorite penetrant  on and get the linkage all loose under there.
This page was generated in 0.057 seconds.
