D17 Hard to steer
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Topic: D17 Hard to steer
    Posted: 06 Sep 2012 at 1:13am
My Dad's D17 with manual steering is unreasonably hard to steer. My question is to you who may have remedied such a problem as to the best course of action, and where to find the best deals on replacement parts.......Thanks for your input!
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2012 at 1:56am
Hey Eric,
What type of front end does it have, Wide or Narrow???  First thing I would do is raise the front end of the ground, and block it properly.  Have someone sit on the tractor and steer the wheel back and forth, and look for what binds or moves freely.  Since it's manual steer, there isn't much to bind before the rack and pinion, but check the steering shaft were is goes through the bell housing, for free movement, caked on dried grease, also check the u-joint, to see if it is stiff.  After that it's either internal to the front pedistal on a narrow front possibly a  lower support bearing going out, or on a wide front, it could be a stiff ball joint, or a the drop shaft running down to the tire.  Ususally on a D-17 things are kinda worn and loose on the steering, so while the driver moves the wheel back and forth, you should bairly quickly see what is moving and what isn't.  Ass far as parts, I go to AGCO for anything internal to the front pedistal, tie rods I get from vendors on this site.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2012 at 5:27pm
Thanks for your detailed answer. It is a wide front end.....we'll do some homework with your recipe, I really appreciate your time in responding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2012 at 5:38pm
Jack up each front wheel and grease each spindle liberally so grease is coming out top and bottom. Remove the grille screen ahead of the radiator and make sure the front support has got oil in it above the gear you can see. I'd use gear oil but any type of oil is better than nothing. Also air up your front tires pretty hard, say 35 to 40 psi. Your perception of steering effort being high, just might simply be the way it is.....that's why 95% of them have factory power steering.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 12:27am
Thanks DrAllis, we'll put your ideas to work and hope for some improvements.
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 4:08am
is this something that just happened or has it been slowly getting worse?
DonDittmar View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 9:08am
Had a D14 that was the same way......nature of the beast
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 1:47am
Dad bought this D17 not very long ago and it was hard to steer from the get-go. My thought by posting here I might find out if this is somewhat common or typical with this model. We have several other A-C's with manual steering that work fine. Thanks again everyone for your time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 7:49am
Well, any non power steering tractor is not easy to steer.  If you add a loader, it's even worse of course.  let me ask you this, when moving around the yard, is it fairly easy, or still real stiff.  Just siting still it will take some major effort?  It also depends on you, and how strong you are.  I am a pretty big fairly strong guy, and what I think isn't easy, is just plain impossible for smaller guys, that aren't ripped! LOL
Still in use:
Alberta Phil View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 10:11am
When I got mu D17 with power steering it steered very hard. I soon found that the top bearing on the steering column just under the steering wheel had gone and allowed the whole column to drop. I replaced the top bearing and now it's fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 4:53pm
Our Ser I D-17 we had back on our farm did not have power steering.Cultivating with the front mounted cultivators would make a man out of you fast
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 5:16pm
oh man !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 12:13am
Originally posted by Alberta Phil Alberta Phil wrote:
When I got my D17 with power steering it steered very hard. I soon found that the top bearing on the steering column just under the steering wheel had gone and allowed the whole column to drop. I replaced the top bearing and now it's fine.
It always helps when you hear what someone else did to improve the task at hand......Thanks Phil !
