D17 Grill Thumb screws
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Topic: D17 Grill Thumb screws
    Posted: 05 Apr 2023 at 2:01pm
A year or so ago, there was a thread showing thumb screws that were used to hold the grill in place on a d17.  Enabled removal and quick access to the power steering fluid fill.  Anyone know what size those are or what's used?  Thinking stainless steel is the best
D17 Series 1
Allis B- 1939
Allis B- 1945
JayD-17(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayD-17(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 2:52pm
I think it should be 5/16 dia. Coarse threaded? Just try a bolt that size in the treaded hole and see if it works. I believe the early D series used different style head on the thumb screw than the later models. One was fancier. You can get them on ebay or most aftermarket dealers but they get a little pricey. I think my local ACE hardware store carries the plain standard kind for about a $1.50 or so a piece.
Edited by JayD-17(NY) - 05 Apr 2023 at 2:52pm
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 3:07pm
McMaster has quite the selection
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Sherman Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sherman Farms Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 3:40pm
All the D series tractors that we have, have wing nuts.The D-15 that I drove home new from the dealer in 1962 had wing nuts to hold the grill. I bought a large bag of them at Fastenel for a small amount of money.
B, C, RC, 3 wc,2 wd,3 wd45, d15, d17, d19, d21, 190, 440, 7040, 918 backhoe, 12 roto balers, 7 60 combines, 40, 66,2 72,90 super, sp100, Gleaner E, F3, 3 L2, R62, and much more
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 5:33pm
Example later D-14 Grille:
232720 2 upper Wing Nuts
232721 2 lower Wing Screws
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2023 at 5:43pm
Thanks all.   Tractor is down at the Farm and 100 miles away so was trying to nail this down so I can deal with it next trip.  And, like Sherman Farms, I may need wing nuts instead (thinking there might be nuts on there now)
 JoeM thanks for that chart.  It's the spade head stainless that I was thinking of.
Gary, thanks for the parts no.  I'll give it some study.
Scott
D17 Series 1
Allis B- 1939
Allis B- 1945
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2023 at 10:05am
My D-17 (Ser. II) has 2 wing nuts on the top and 2 wing bolts on the bottom.
i just looked in my parts manual and that is what is listed there as well.
I believe I replaced the wingnuts years ago so they may not look original.
The wing (or spade) bolts may be original but I can't say for sure.
In any event, the bolt and nut sizes are both 5/16" NC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2023 at 1:29pm
Our 57 D17 I think has regular flat headed screws in grill. Has little tabs on top that it slides into with screws on bottom 919113
And like Brian said. sr no. D17-24001& up uses top wing nut 232720 and bottom 232721 wing screw
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2023 at 2:05pm
These are the factor style thumb screws.
The wing nuts should be the flanged ones.
This page was generated in 0.089 seconds.
