D17 governor thrust bearing
Doobletango View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doobletango Quote  Post ReplyReply Direct Link To This Post Topic: D17 governor thrust bearing
    Posted: 12 Oct 2020 at 6:07pm
Hey guys, I’m getting my engine back together and am ready to install the governor assembly. I see there’s thrust bearing on the carrier that works with the governor weights. I know this may be a dumb question, but the thrust bearing appears locked into the carrier instead of spinning freely in it. I’m assuming this is wrong-that it should spin freely? I see bearings inside the holes on the side.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2020 at 8:46pm
One thrust washer is usually stuck to spool, then the bearing and another thrust washer free to rotate.          MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doobletango Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2020 at 7:23pm
Any idea where I might find another? Google isn’t showing much...
