D17 Gas won't start
Dean View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean Quote  Post ReplyReply Direct Link To This Post Topic: D17 Gas won't start
    Posted: 18 Aug 2018 at 10:36pm
I have a D17 gas that only gets used for parades and the like.  I had it warming up and it started running poorly so I gave it some more gas and it died and it won't start.  I removed each spark plug, grounded them one by one and cranked the started all of the plugs fired.  Must be gas problem. I drained the tank, cleaned it and the fuel line and Sediment bulb and found nothing. Still won't start  I took the carb apart and found nothing so I took it to the dealer who put a kit in the carb and it still won't start.  Sometimes it will pop and fire like it is trying to start.  Any help is appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2018 at 11:59pm
Try a different condenser. Most points and condenser come from the land of almost right and quality is just about non existent.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 7:43am
Brian is probably on track.  I would slick those points up or replace for grins while in there.
Some stealer there, they shoulda had it purring in no time.  Confused
Edited by Dave H - 19 Aug 2018 at 7:44am
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 7:58am
Have you checked to make sure the distributor shaft is turning?
Dean View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 11:05am
No Points replaced with electronic
Dean View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 11:10am
No points or  condenser replaced with electronic and I have spark at the plugs.  Doesn't spark at the plugs mean it is working electrically?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 11:10am
Is it a nice blue spark? At least 3/8 inch long? Have you changed the plugs lately? Is the inside of the distributor cap all nice and shiny and clean and dry? A plug fires differently under compression than in open air.
Edited by DougS - 19 Aug 2018 at 11:11am
Dean View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 11:13am
No, I have not checked the shaft, great idea!
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 11:14am
if you have a timing light, set up with it on the coil wire, crank the engine and see if you have uniform spark.
Dean View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 11:17am
I'm going to recheck the amount of spark, may not be enough.  Plugs are new, I'll recheck the cap and rotar and make sure distributor shaft is turning.  Thank guys you gave a rookie some great new ideas
lowell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 11:44am
If you have spark the dist must be.turning other wise what would cause it to spark
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 11:59am
Had basically the same problem with my D15. Took out the electronic ignition and went back with a good set of points and condensor, kept the Flamethrower coil in there and it has been running great since.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 12:36pm
You are right, but is it turning all the time. I have heard of the gear turning on the distributor shaft, throwing it way off on the timing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 1:11pm
It does happen once awhile good way to check it is to put it to Tdc and see were the rotor pointing
squirt239 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote squirt239 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 1:38pm
Is it getting gas from the carb to the motor?  Is the float stuck in one position in the carb?
I'd get rid of the electronic ignition.  I had one on my D14 and it ran like poo.  Changed it back to the points and condenser and it runs great.
Another thing that I had wrong on mine was the distributor had "slipped" out of timing.  Might just check to see if those bolts are German...you know...goodntight :-)
Best of luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 1:42pm
One more thing. Twist the distributor and ensure that it is tight. If not, retime the motor and tighten the bolt.
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 8:15pm
Gee had same problem... mine would not run unless on choke.
My solution....went back a few days later, tried again and it ran fine..
My D17 drives me nuts sometimes...
Dean View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2018 at 11:08pm
Thanks guys, I'm going to do some more checking.  It does seem to be something like the gear slipping on the distributor shaft or a little pin broken somewhere.  I'm thinking that way because one minute it was running great and the next it won't run at all.
