D17 fliud levels/torque tube |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8499 |
![]() ![]() ![]() ![]() ![]() Posted: 14 Jun 2012 at 12:01am |
Left side hex plug is trans? What/why two dipstick/breather combos on right.One opposite hex plug and one up by pulley block off plate. Frt rt one was 3in over full mark,rr rt one spot on and hex plug about 1in over full. Drain some or not? TIA
Jordan(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Celina, OH Points: 1552 |
Hex plug is PD, other is trans. One on side of housing is hydraulic. I wouldn't drain any, if you use any large cylinders you will need the extra in the hydraulic. I use mine on a Mayrath auger sometimes and it is at least 3in over all the time, forget how many gallons I had to add to get it to raise first time.
If you are talking about allen head plug in side of torque tune, it is for the return from transport valve if it has one. The plug on right on top is trans. The one on top on left is for PD and Hyd. if series 111 or later. If it is early tractor hyd. will be on torque tube under fuel tank. MACK
When I split it at clutch,oil started running out of front of hsg behind throwout brg. I had to suck some out the front compartment to make it quit. Been sitting it the barn for a year with no leak there. Is there a seal up there?
It's an earlier model.Lights on radiator,bypass oil. Edited by SteveM C/IL - 14 Jun 2012 at 7:44am |
OrangePowerFranzen ![]() Orange Level ![]() Joined: 05 Mar 2011 Location: nashua Points: 228 |
i just got our 17 back toghether and i have the same leak right behind the throw out bearing on the torque tube. i looked in the book and see there a gasket and 2 oil seals that are there, i plan on re splitting it and replacing it sometime next week, dont want to but have to. im going to check with agco tomarrow to see how much all that is, i hate to go there bc there prices are sky high! o well
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
They aren't all that bad from AGCO, you will want the front gasket too. You need to drain the front torque tube housing, and leave the plug out, or you will get a bath when you pull out the front bearing "tube" that you are working on.
Still in use:
Well PHOOEY! It was kinda messy inside clutch hsg so I'd say it's been a seeper.Guess I ought to look into fixing that while it's split.Have no book and never been around a 17 so does that all fix from the front? Noticed the input shaft kinda runs uphill out of the sleeve so I'm guessing the PD is hanging on the back end and maybe the shaft cocking when split upset the seal/seals?
It is an easy fix, it all come out through the front. Just make sure you drain the oil first!!! As for the shaft being uphill, I bet the sleeve is what is actually crooked, but in any case rotate the input shaft a few times and make sure it is always in the same spot, i.e. does the crooked part rotate around, or does the close spot always stay at the top, i.e. is the shaft straight. I have a feeling that some of the tubes were welded crooked to the flange that holds them to the case. I have seen a couple dozen of the 17s apart, and at least two with a crooked bearing guide tube. It really doesn't hurt anything that I can see, as the throwout bearing tends to be loose enough on the carrier to allign with the cluth pressure plate, or the fingers on the pressure plate simply run in and out slightly as the flywheel rotates.
Still in use:
Thanks for input Orange. Rolled that shaft and seemed straight.
thank you i was going to ask the same thing about replacing it, i just hope i remember to drian the oil!!
