D17 engine- what most likely broke? |
Foreign.Perspective ![]() Bronze Level ![]() ![]() Joined: 22 May 2017 Location: Texas Points: 71 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Aug 2022 at 7:57am |
Have a D17-IV, Gas. Was mowing pasture a couple of days ago and all running fine. When I stopped for the day, after Ole long to cool down, I turned the key off ant the engine backfired and made a huge clanging knock in the engine.
Yesterday when I went to start it, it spun over like there was no compression, backfired occasionally and would not start. The front crankshaft pulley and the distributor are turning. Any idea where to start looking? Any help would be appreciated. Thanks!! |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21998 |
A good place to start would be remove all the spark plugs, pull the throttle wide open, connect a battery charger and run a cranking compression test.
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1335 |
I would be inclined to pull the spark plugs and then try turning the engine over by hand to feel for any abnormalities, then run the compression test as mentioned above. Good luck! |
DanWi ![]() Orange Level Access ![]() ![]() Joined: 18 Sep 2009 Location: wttn Points: 1937 |
Not sure how that motor is but might guess a broken cam or gears.
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9922 |
Sounds like a possibly bad valve.
Pull all spark plugs and check their condition. Check for compression. Sometimes a valve stem may carbon up and keep a valve from closing fully. This may cause the engine to fire improperly. You may want to remove the valve cover and inspect and adjust the valve train. I was swathing with a New Holland 1114 diesel swather and lost a piece of a valve. It was running fine until I shut it off. After lunch, I started the engine and noticed a slight tapping sound. A piece of the valve broke off and embedded into the top of the piston. Fortunately, it did not score the cylinder or damage the head. Replaced all valves and had the head serviced by a machine shop. Piston, gaskets, valves, misc. parts and machine work was $736.
Well, I finally got off work and did a compression test on the engine.
I pulled the plugs and all 4 looked good, with no major difference between them. All 4 cylinders were between 180 & 195 psi on the compression test, So, all valves and pistons are ok. I’m guessing the most likely next step is to check the camshaft gears to see if it broke some teeth and the cam is out of time with the crank. Does that sound logical? Can I access the cam& crank gears in-frame or will I have to split and remove the front bolster or the entire engine? I appreciate all the replies and ideas. Thanks!! |
JPG AUSTRALIA ![]() Orange Level ![]() Joined: 13 Sep 2009 Points: 767 |
I would think if your compression is good the cam would be fine,
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54255 |
Check the timing. Could be the dizzy drive gear has shifted/broken pin...
nella(Pa) ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3124 |
X 2 I have herd of governor weights breaking if you herd a cracking noise!
Edited by nella(Pa) - 21 Aug 2022 at 6:04am |
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5031 |
Next I would remove the distributor cap and see if it is turning (smoothly) when the engine is turned over. Put the rotor back on and see if it turns while holding it.
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4100 |
All 4 cylinders were between 180 & 195 psi on the compression test, It would be interesting to know what pistons and sleeves it has in it. Pretty high compression numbers. Not a bad thing, just a curiosity.
Sounds more like a timing problem. Roter broke, gear on bottom of distributor, or governor gear. MACK
Your compression is good enough to run, but your tester must be incorrect. Any D-17 gas with stock pistons and sleeves should be 145 psi. A 170 or 175 would be 170 to 175 psi. Your numbers are beyond any AC spec.
Ryan Renko ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2336 |
aclongb56 ![]() Bronze Level ![]() Joined: 07 Sep 2021 Location: michigan Points: 15 |
Check the point's, and disturber cap, and rotor.. Gas also we run rec gas in all of ours, lot more $ Now days When carb starts frosting up,, looks like white frost.... 90 octane or btr.
25-40,A,U,UC,Styled,unstyl,WF'S,WC'S,WC ROAD PATROL,WD'S WD45,RC,IB,3 Waukesha B,B'S C,CA'S,G'S,D12,D15,D17,B-10 thru 919 L&G.... Father's and Boy's and Toy's... Just don't let MOM know!!
corbinstein ![]() Orange Level ![]() Joined: 31 Jul 2014 Location: Oklahoma Points: 796 |
I'm with the rest of the boys. Cam probably ok. check your dizzy drive.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8646 |
Be interesting to see the final outcome.
Alex09(WI) ![]() Orange Level ![]() ![]() Joined: 15 Mar 2012 Location: CECIL WI Points: 1752 |
check to see if rotor is going around when cranking and remove distributor from horizontal drive to check for worn teeth on dist. drive gears
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
