D-17 D series II transmission issues
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2020 at 9:23pm
PM me your email and I'll try to email you the manual I have.  It's an IT manual but it shows c 1966 so I think it's before they went bad.  It's a big file so it may take me a minute to figure out how to email it to you.  You'll probably need a Yahoo or similar email.
SSD17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SSD17 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 12:11pm
When installing the pins for the gear bushings the manual says to install bushings with lock pin forward. Is that forward toward the clutch shaft? The illustration is showing rearward toward the pinion shaft?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 12:34pm
Forward towards the radiator. I think the only one that really bothers on is 3rd gear.
This page was generated in 0.085 seconds.
