D17 brake adjustment? |
Hunt4Allis ![]() Orange Level ![]() Joined: 13 Mar 2018 Location: Ohio Points: 1172 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Apr 2021 at 6:26pm |
brakes take a long push on pedal to engage, also seams maxed out on brake lock position...
Brakes work ok but won't hold on a small incline with brake lock? ( Can I adjust brakes and hold lock lever tighter?)
jlogli ![]() Orange Level ![]() Joined: 12 Oct 2011 Location: Stockport, IA Points: 862 |
What series of 17 are we dealing with here?
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Series 1
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5020 |
Be very careful that you don't twist the adjusting rod off when you are trying to turn it. I hope you have better luck getting them to turn, than I did.
Edited by WF owner - 08 Apr 2021 at 7:37pm |
DanD ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: WI Points: 856 |
Brake adjustment for early D17's is done under the brake covers, not by turning threaded brake rods (that's the method for newer D17's with the band/disc style of brakes). In a nutshell, you tighten the big nut you see under the brake housing cover to pull the bands closer to the drum. And you use the bolt at the back of the brake housing to equalize front and rear halves of the bands. The proper procedure is listed in the service manual. I can't recall of the details though so be sure to read the procedure or see if someone else will chime in.
Hmm, I'll have to look and see if I can see it and get to it... Maybe spray a few times with some oil first
