D17 axle guts |
sks72107 ![]() Silver Level ![]() Joined: 30 Sep 2010 Location: Logansport, IN Points: 441 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Oct 2012 at 7:11am |
Well i ordered some parts last night from agco to reseal the rear axles and final drives of the D17. Just one problem. I forgot to order the pan gasket that goes right below the bull gear!! So the question is. Do i change my order or should i just use some good sealant and call it good?? Also, the tapered roller bearings on the pinion shaft dont really roll smooth(dry, no oil) after cleaning. Should i go ahead and replace them also. they dont look bad, they just dont roll real smoothly after cleaning them. If i replace them should i replace the race also?? Thanks
Redwood ![]() Orange Level ![]() Joined: 16 Jan 2012 Location: Ontario Points: 631 |
In general if you have to ask...it stands to reason you think it should be done so do them.
what is the cost vs pulling it apart again. If your in a hurry to get it running and changing the order will cost you time you don't have It probably will work if they are clean and smooth.
Me in a hurry?? LOL. Not really in a hurry, but its time to get the old girl back on her feet with brakes this time. Ill give the parts store a shout, Id hate for those housings to leak:( Thanks for the input.
Called Agco and they can get my pan gaskets for less than $8, How could i say no to that. They are on their way.
David(Stockbridge)MI ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: Stockbridge MI Points: 536 |
Have bull gear pan gaskets in stock. www.djstractorparts.com
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler |
jnicol6600 ![]() Bronze Level ![]() Joined: 02 Jul 2011 Location: Sullivan Co. IN Points: 174 |
Go to tsc or rural king and buy some cork gasket material and cut your own.
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3048 |
If you replace a bearing, you should always replace the race too. Once you get it running you need to take it to the power from the past show in winamac next July so I can see it. Or better yet, take it to their plow days next fall and we'll let our Allis's show everyone how to really plow!
Edited by Allis dave - 03 Oct 2012 at 7:25am |
