D17 axle guts
sks72107 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sks72107 Quote  Post ReplyReply Direct Link To This Post Topic: D17 axle guts
    Posted: 02 Oct 2012 at 7:11am
Well i ordered some parts last night from agco to reseal the rear axles and final drives of the D17.  Just one problem.  I forgot to order the pan gasket that goes right below the bull gear!! So the question is.  Do i change my order or should i just use some good sealant and call it good?? Also, the tapered roller bearings on the pinion shaft dont really roll smooth(dry, no oil) after cleaning.  Should i go ahead and replace them also.  they dont look bad, they just dont roll real smoothly after cleaning them.  If i replace them should i replace the race also?? Thanks
Redwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2012 at 7:22am
In general if you have to ask...it stands to reason you think it should be done so do them.
what is the cost vs pulling it apart again.  If your in a hurry to get it running and changing the order will cost you time you don't have It probably will work if they are clean and smooth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sks72107 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2012 at 11:54am
Me in a hurry?? LOL.  Not really in a hurry, but its time to get the old girl back on her feet with brakes this time.  Ill give the parts store a shout, Id hate for those housings to leak:(  Thanks for the input.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sks72107 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2012 at 12:20pm
Called Agco and they can get my pan gaskets for less than $8, How could i say no to that. They are on their way.
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2012 at 5:38pm
Have bull gear pan gaskets in stock. www.djstractorparts.com
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
jnicol6600 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jnicol6600 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2012 at 6:52pm
Go to tsc or rural king and buy some cork gasket material and cut your own.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2012 at 7:23am
If you replace a bearing, you should always replace the race too. Once you get it running you need to take it to the power from the past show in winamac next July so I can see it. Or better yet, take it to their plow days next fall and we'll let our Allis's show everyone how to really plow!
Edited by Allis dave - 03 Oct 2012 at 7:25am
