d15 with shuttle
one54dodgetruck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Topic: d15 with shuttle
    Posted: 04 Jun 2015 at 1:42pm
Hey guys I have a d15 with a shuttle and have a few questions. Is it ok to feather the shuttle clutch? Has anyone used this set up to brush hog? I know the pto will be spinning around 800 rpms, but cant the throttle be backed off enough?
Thanks
Andrew
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2015 at 5:16pm
I was always told by my grandfather that the dealer told him the way to bail hay with a d17 was to feather the shuttle clutch whenever there was a big clump of hay. The same d17 is one I am currently working on today because the shuttle clutch finally gave out but after several decades of bailing hay in this manner and I also found that my shuttle clutch had been run dry. I have posted a question about how to fill it and with what oil. But it is my understanding and experience that the shuttle clutch in the d serries tractors are designed to allow you to slip them in order to provide live power.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2015 at 5:45pm
As long as they have oil you can slip them. They are a wet clutch, the oil cools them so they are pretty tough. The original spec was non detergent 20w but that can be tough to find so I use universal tractor hyd fluid or AW32
1968 D15D,1962 D19D
