D15 transmission gears
combinechris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Topic: D15 transmission gears
    Posted: 09 Nov 2017 at 12:55pm
where's a good supplier to get transmission gears for an early 1961 D15 tractor. I plan on restoring mine and need to go through the whole tractor from front to back with the restoration.
Edited by combinechris - 09 Nov 2017 at 12:55pm
35 combines and 15 forage harvesters. mostly allis combines and equipment.WTB 2 row cornhead for a 90
Post Options Post Options   Thanks (1) Thanks(1)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2017 at 1:07pm
don't know BUT if the PTO lever is the same as my D-14 replace the 25 cent O-ring while it's all apart !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2017 at 1:51pm
will be replacing a lot of the seals on it .
CAL(KS) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2017 at 2:09pm
A&I makes transmission gears.  Im not sure what is available for D15 but some of our sponsors may sell them.  I know they make for 190 and others
Gary View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2017 at 3:10pm
The good news about the early D Series transmission gears is they are practically all the same.
Ie CA, D-10, D-12, D-14, D-15, also some in D-272 and ED-40
Gary
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2017 at 5:00pm
Some of the gears are different but can used it the mating gear is replaced with it. You would have to know the serial number breaks. Check the parts book.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2017 at 9:01am
AGCO still supply's gears but are very pricey. A & I may sell a few as well. Just remember that all the gears from the CA-D-15 are interchangeable, just be careful as the gears had rev changes and must be changed in pairs or sets.
Thanks & God Bless
Dennis
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2017 at 5:38pm
Early CA gears may not be interchangeable with the later. Parts book shows a change from CA 13291
Oldskewl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldskewl Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2017 at 6:46pm
I repaired my transmission 1960 D15 and didn't buy anything in fact if you buy the gears and reassemble like it was from factory it will for sure do the same thing it did from the factory you have to fill and recut the detents so it shifts all the way into gear in every case I have seen 1/3 of the drive cog is being used if you polish it up and make it shift the other 2/3 of cog left will last longer then new parts. Also build up and re file shift forks to match the collars again and make sure it moves reverse gear out enough that third gear no longer rides on it when engaged. This job is not for the easily intimidated but with or without parts you need to follow all these steps or they will do the same thing again Dr Allis has a good post about it on here.
Edited by Oldskewl - 10 Nov 2017 at 6:47pm
Fred in Pa View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2017 at 6:34am
I have factory chart that shows when using gears how to match them up ,I also am right now rebuilding (changing ring n pinion ) a D-15 trans for a customer .
Can scan and post chart  later this weekend
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2017 at 10:28am
thanks Fred. by the way guys my D15 serial number is D15-5442
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2017 at 8:27pm
That chart would be great Fred. I have 2 D15's on the back burner lol
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2017 at 7:28pm
 Also sent you a few other print outs to your e-mail
Edited by Fred in Pa - 14 Nov 2017 at 6:14am
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 6:21am
djs has gears
