D-15 steering flop
Farmer1782178 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmer1782178 Quote  Post ReplyReply Direct Link To This Post Topic: D-15 steering flop
    Posted: 27 Jan 2015 at 12:59pm
Alright so i have a 1961 allis chalmers d15 nfe and it has play in the steering. When we had the motor out we removedthe shims where the steering shaft(from the steering wheel) goes into the steering housing in hopes of removing some of the play. Well it did help a lot, but it still has about 1/4 of a round of play an it will shimy going down the road. I believe it is in the steering worm bearing and the other bearing on that shaft not the part that goes down to the wheels because there seems to be no play in that and when it shimys i can hold the wheel all te way to either side of the play and it wont shimy. My question is where can i get those bearings? I know i can get the steering worm bearing for it from steiner but thats the only bearing that i can find for it and i know there is two in there because i an see it on my book. The steiner site also shows that i only nee one of the steering worm bearings per tractor. Do yall think the bearings are wore or something else
Thanks, Luke
Edited by Farmer1782178 - 27 Jan 2015 at 1:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2015 at 4:06pm
Motion Industries will have just about ANY bearing you can ever need. https://www.motionindustries.com/miLocations.jsp
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2015 at 5:39pm
You have to be careful on some of this stuff. Some bearings were made by Timken specifically for AC. When this happens the bearing is usually captive, meaning it must be bought through the dealer. I ran into this on the D14 I did many years ago.
Now this is not to say a good bearing house won't have a bearing that can be made to work with slight modification......
1968 D15D,1962 D19D
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2015 at 5:53pm
Check the 2 universal joints in the steering linkage - If these are worn, they can contribute to play in the system.  AGCO carries the bearings that you need.  Check your tie rods while you are at it too - another source for play.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmer1782178 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2015 at 9:57pm
The universal joints are fine(no play) and there are no tie rods... It's a. Narrow front end
TOMIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TOMIA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2015 at 10:44pm
There is a splined coupler that connects the lower pedestal with the shaft out of the bottom of the steering gear. On my D14 the splines were worn and that is where my play was.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2015 at 7:33am
My crystall ball says the bearings are fine.  Get the front of the tractor off the ground.  You can usually find where the slop is easily at that point.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmer1782178 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2015 at 11:35am
What did you do about the splines being worn? I believe the bearings are worn because when we took them out they had the tendency to come apart, not stay together like a bearing should. Also, I'll check but I don't believe there is any play where the two shafts connect. How would I tell if I jacked up the front end? Never thought of doing that but not sure what I would check?
Thanks, Luke
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2015 at 11:48am
With the front wheels off the ground, I'd remove the oil fill tube behind the grille and look inside. You might have to drain down the oil level to see the steering gear. Watch the gear and turn the front wheels back and forth just enough to not move the gear inside. I'm thinking worn splines on the pedestal coupler and gearbox output shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TOMIA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2015 at 1:13pm
15 years ago the coupler was available from AGCO but it wasn't cheep, $250 if I remember right.
