D-15 questions
edmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote edmo Quote  Post ReplyReply Direct Link To This Post Topic: D-15 questions
    Posted: 13 May 2011 at 4:21pm
Just joined and have a couple questions, hope I'm not rehashing some old information.  I have my dad's D-15 he bought new in 1964.  It only has about 1700 hours on it and I think the rear tires (14.9x26) are the originals,  They have good tread left, but are falling apart from weathering and age.  I'm trying to find some used ones that are not worth more the the tractor and found a set of 13.6's off and old Gleaner.  I see that AC put both sizes on a D-15 and just want to make sure the my wheels will work.  I assume so, but have been wrong more than once before.
Also, I'd thought about trying to get a loader for it, but the guys who seem to know about loaders talk like the hydraulics on the D-15 aren't adequate.  I understand I can get an add on at the PTO, but need it for other stuff.
Thanks for any and all input.  Ed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 5:46pm
If you put a loader on it, it's best to add a pump on the front driven directly from the engine. The original hyd system is driven from the pto shaft in the torque housing. It's a high pressure/low volume system compared to modern hydraulics. Every time you step on the clutch, the hyd pump stops too making loader operation not very convienient.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 6:38pm
edmo
I have a Freeman #180 loader that was mounted on a D17 SIV that I might consider selling.
It has the larger lift cylinders meant for lower pressure (2500), and has a trip loader with snow extensions.  If you're interested, reply to post.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 8:44pm
I have a front pump/loader setup for sale that came off a D-15. You don't list your location so I'm not sure if your interested.
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 9:04pm
Better to use  14:9x26 tires over the 13:6x26 tires.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 10:54pm
I would recommend the 14.9 tires and a loader with a front mounted pump as well.
edmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote edmo Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2011 at 8:35am
Thanks for the replies.  I've got a couple loaders located locally (So. Missouri) and trying to figure out the hydraulics add on.  Anybody have an idea of the expense involved and where available?
Guess I'll bite the bullet and get the 14.9's new.  Best I can find is about a $1000 installed.   All the used ones I have found are sandbox quality.
Thanks again.
