D15 Power Steering lines
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: D15 Power Steering lines
    Posted: 10 Jan 2012 at 9:33pm
Have a look at this.   The AGCO parts book website shows the power steering lines going to the governor??  Is this right?
Both my D14 and D15II have the same pump that is located below (and separate from) the governor.
I am looking for a new line that goes from the back of the pump (closest to the engine) and connects where the steering shaft goes into the front casting on the left side.  Does anyone have any of these lines (new or a good used one)?  Even the part number would help.  AGCO website shows the line as 70233483, but is not even close to fitting my tractor.  I appreciate any assistance that can be provided!
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2012 at 10:34pm
I literally just came in from the shop making that particular line..
I just used brake line and flared the ends and bent it accordingly
worked out just fine.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2012 at 10:44pm
Funny thing here also is I spent a good portion of time today looking at the A-C and IT repair manuals as I have a narrow front apart on a D-14 trying to get rid of some steering slop.  I would say the above picture is showing an early D-17 power steering set up not a D-14 or 15.  Also, does anybody know if the splined coupler that couples the pedistal shaft to the shaft on the steering gear available anywhere.  I am not referring to the coupler that the steering shaft fits into, but the one inside the housing.
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2012 at 10:52pm
I looked it up for a D14 and the parts picture looks correct and a D14 should take the same line as a D15. The part number is  70228688.
