D15 power steering control valve leaks
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Topic: D15 power steering control valve leaks
    Posted: 26 Aug 2015 at 11:02pm
I have been working on my d15 with a loader today. Turns out my power steering leak is the seals on the control valve the oil just runs out of the valve seals. The real kicker is it steers great as long as the oil is still their. But the leak is hopelessly bad and has to be fixed.
Is the service manual correct that I have to remove the front counter weight in order to access the control valve or is there some trick which will save me some disassemble?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2015 at 10:34am
The front casting has to come off to replace the seal where the steering shaft goes in on the left side.  Far easier to work on it without it on the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2015 at 10:37am
Thanks I just wanted to double check before I started.   I think I can do that without having to pull the loader.
