D15 II steering
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: D15 II steering
    Posted: 11 Jan 2012 at 9:49am
question for yall. Diamond Girl is back to working really well for me but this winter I still have an issue to fix. When I pour in the power steering oil in front of the radiator in a few days time it will be empty. It is leaking right below where the bottom shaft comes out of the steering box which is attached to an arm which has the tie rods attached. I guess I am asking for that seal number which must have to go in from the top side to seal oil from leaking out that bottom shaft. Any help will be much appreciated. Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 8:05am
Bump
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 8:14pm
Capt. if the seal is leaking something has damaged it or more likely the bushing is also worn out. You'll likely need to remove the front section and flip it over and remove the bearing plate and replace the bearing and seal. It's a lot of time but not that hard to do.
Be a great time to re-bush the pivot while your in there.
Yea, I can fix that.....
