D15 hydraulic fluid cap location? |
MDtractor ![]() Bronze Level ![]() ![]() Joined: 24 Dec 2021 Location: Kansas Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Dec 2021 at 11:11am |
I inherited an old D 15 from my father in law...he has always talked about how the scoop and the brush hog have a tendency to ever so slowly lower down.....I am trying to locate the hydraulic fluid cap...right in front of me below the seat to the left of center is a hole that would have originally had a cap on it but it has always been stuffed with an old rag (lost cap) ever since I have known the tractor.... Is that the hydraulic fluid hole for a cap. Someone thought having a true cap on that hole might help seal in the pressure....
for that matter I need to learn where the transmission oil is etc.... it has always run for the most part on what my father in law called "deferred maintenance" ![]() ![]() Any help on hydraulic fluid location would be appreciated...and if I have the right location...getting the right cap for it....
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22015 |
Hydraulic oil check/fill location is under the gas tank on the right side of the torque housing. Transmission/differential oil is close to the gearshift. Power Director/PTO gears is next to the instrument panel on the left and takes a wrench. Power steering oil is behind the grille screen.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7513 |
The spot that has a rag stuffed in it should actually have a dipstick in there to monitor fluid level.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24727 |
If the hydraulic pump section is low on oil(checked running, loader up max high...), check the diff dip stick ! Might have rockshaft ram seal slowly leaking......
