d15 distributor #
cobra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cobra Quote  Post ReplyReply Direct Link To This Post Topic: d15 distributor #
    Posted: 23 Jan 2012 at 4:47pm
i need to order tune up kit. i think its a delco distributor the info plate on the side numbers are i think  11114?? does this look right or is there another wqy of determining the right parts i need
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 6:52pm
Any good parts store (NAPA for example) can get you what you want.....they are all the same for points/condensor/cap/rotor....CA-WD45-D14-D15-D17.....and of course any AGCO dealer probably has them in stock.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 6:57pm
   we have the tune up kits   1-800-254-3116
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 10:36pm
The D15 Series I & II gas tractors were equipped with the Delco 1112607 Distributor. Most all the internals for the Delco Distributors used the same components. We have complete tune-up kits in stock for your particular application. The I 60 & I 600's used the same Distributor also.   HTH
Steve@B&B
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 11:17pm
I might be wrong, but I seem to recall my series II D15 using a different set of points than everything else.  I'll try to remember to look tomorrow.
JimD
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
