d15 clutch
cobra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cobra Quote  Post ReplyReply Direct Link To This Post Topic: d15 clutch
    Posted: 20 Jan 2012 at 10:58am
can you ajust the clutch on a d15 series II gas . the pressue on the clutch pedal seems to have gotten slacker. is this a sign of clutch problem and if so whats the fix   thanks
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 11:10am
Does the clutch still function properly,does clutch pedal come all the back?
Post Options Post Options   Thanks (0) Thanks(0)   Quote cobra Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 11:13am
clutch does come back seems to be more play  in clutch pedal when yuo first depress it
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 11:23am
When you depress the clutch,any trouble getting it in gear,does the clutch slip now?
Post Options Post Options   Thanks (0) Thanks(0)   Quote cobra Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 11:30am
clutch seems to work ok no slippage but just wondering why a difference in clutch pressure
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 11:33am
Sounds like broken spring in pressure plate,might continue to work ok unless it starts to slip under load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cobra Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 11:35am
thanks for info        smitty
