d15 clutch replacement |
cobra ![]() Silver Level ![]() ![]() Joined: 16 Oct 2011 Location: p.e.i. canada Points: 66 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Jan 2012 at 10:05am |
this spring i plan on replacing the clutch on my d 15 gas.is this a big job and are parts expensive as i thought i should start buying them now.does the tractor have to be split to do this ( i'm not a mechanic) and what else should i look at while doing this (somemtimes pops out of third) can i do this my self im not a mechanic but can do minor repairs. thanks smitty
Brian S(NY) ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: CherryValley,NY Points: 3378 |
Yes,ou need to split it. Be very careful if you dont have the proper equipment to split it the job can turn into a nite mare. Find a freind who knows what to do and get them to help you. otherwise send it out. Parts are not that expensive. we did mine a year ago. Third gear problem is transmision. totally different work area.
thanks for help smitty
