D15 160 engine valve train kit |
cottonpatch ![]() Silver Level ![]() ![]() Joined: 17 Nov 2010 Location: VIRGINIA Points: 285 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Aug 2012 at 8:40pm |
Does the 160 engine utilize the same valve kit as the 138 & 149 engines? Conflicting data out there on the internet. I was at the Agco dealer today and he did not even have a listing for it, Agco or aftermarket (tru-power). Thanks for any and all replies in advance.
BrettPhillips ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Strasburg, VA Points: 808 |
Yes, they are all the same. Even the B, C, and CA use the same valves, springs, guides, and locks.
So just looking in the I & T manual, and it shows the spring free length is longer on a D15 @ 2 31/64 vs the D14 @ 2 5/16? I have a valvetrain kit I bought for a CA and never used previously. I was thinking I could use this kit, but am a little concerned about using the springs from the kit. The manual also states the spring pressure in the D15 is a bit more at the two compressed spring lengths - 14 and 20 pounds more at the two compressed lengths, respectively. ?? |
Anybody....??
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
If you run high enough RPM to make the valves float with the CA kit, you'll probably have something else come apart, maybe out the side of the block
10-4. Just going to use this gal to rake hay, and teach my kid tractor basics. Definitely not looking to turn the wick up on her. I grew up using a D15, and was really excited to pick one up. She sat for a while, and we intend to completely rebuild it front to back. Thanks for your reply, I appreciate it.
