D14 vs WD45 |
Dave in il ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: Manville Il Points: 1748 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Oct 2011 at 8:26pm |
So the D14 was designed to replace the WD45. So in the real world how do they compare? I'm betting a lot of you have both or have had both.
ICTRCTR ![]() Silver Level ![]() ![]() Joined: 17 Nov 2009 Location: Beatrice NE Points: 371 |
I belive the wd 45 ,was replaced by the d-17 engines were very simular .
WD45 ![]() Orange Level ![]() ![]() Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 955 |
The D17 replaced the WD45 .(226 cu in) A few years ago we had 450 bu wagon loaded with corn and hooked our D15 series II to the wagon. Put the tractor in 2 nd and let the clutch out
and it just spun. Unhooked and hooked our WD45 gas to the wagon. Put 45 in 2 nd gear pulled back on the hand clutch and the tractor took off moving the load.
The D14 is a nice tractor with the high low range but the WD and WD45 will out pull it.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
wfmurray ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
We replaced a WC with a D14 and the 14 handled combine with pto better than the WC but the WD45 is a lot bigger tractor and i would compare it with a D 17.
m16ty ![]() Orange Level ![]() Joined: 28 Jan 2011 Location: TN Points: 1474 |
I guess you could say the D14 replaced the CA. That would be a better comparison than a WD45 and a D14.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7484 |
The D14 was not meant to replace the WD45. The 35 hpD14 never had the weight or power of a 45. The 46 hp D15 II is a better comparison, but most believe it was not as strong as a WD45.
I stand corrected. But I thought AC's advertising said the new D14 was the replacement for the WD45 and the D14 was introduced before the D17.
Also I thought the CA was sold along with the D14 before the D10 and D12 were released. Don't have any books here though and my memory isn't what I remember it to have been. Our WD45 was never close to a match for the power of a D17 even with a D17 kit in it, or the comfort level of the D17... well the 45 doesn't really have a "comfort" level. LOL I like the 45 but I love my D17's, theres been quite a few posts recently about D14's and that's what got me thinking about this. I keep thinking a D15 or a D14 might be a nice addition to the collection.
Edited by Dave in il - 31 Oct 2011 at 9:49pm |
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8711 |
If I remember correctly, Norm Swinford's book says that the D 14 replaced the CA, and the D 17 replaced the Wd 45
Did AC consider the D14 a "three plow" tractor like the 45 was? I thought AC called the D17 a four plow tractor. This might be the cause of my confusion...
Dave, they did not consider the 14 a 3 plow tractor, the exact terminology was that it was to say, not quite a 3 plow tractor. That is why it was short lived, and was quickly replaced by the D15. I do have a D14 and a D15 and like em both. Darrel
TedBuiskerN.IL. ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
Actually the WD45 was called a 3-4 tractor, and the D17 a 4-5. There is literature showing the WD45 pulling 4-14s and a D17 with 5-14's. I pull a mounted #64 4-14 most places with a balasted WD45 that dynos 43 HP.
Dennis Anderson from Ridott, IL has plowed with 5-14's behind a D17. A properly adjusted and bright plow, and a working traction booster system allows you to add the extra bottom.
The new "replacement" model always had more power than the model it replaced. That's why you see the up in plow size between models.
The experimental models that led up to the D14 look a lot like a CA. |
Dean(IA) ![]() Silver Level ![]() Joined: 12 Sep 2009 Location: NE Iowa Points: 430 |
D-14 vs WD-45
My brother, Warren, bought a D-14 new. The salesman told him that it was at least equal to a WD and probably as good as a WD-45. The D-14 was a very nice tractor, but if you started to lug it, you had better be reaching for the hand clutch. So. Warren was never really happy with the D-14, even though it never had any problems. After a few years, Warren traded it for a 450 Gas(hog). He finally got the 450 weaned down to 4 gallons an hour. A personal story, I was home from the Air Force on leave, and plowed almost all night with the D-14 and a 3-14's A-C mounted plow. I finally had to quit when I would wake up when the tractor started to bounce on the end rows. (I would turn the front wheel slightly against the furrow wall and then could take a little snooze, when I was going across the field.) We do take some chances sometimes, especially when we are young and invincible. I thought that when I got old, I would get old and wise, but I just got old. |
Josh Day ![]() Orange Level ![]() Joined: 29 Nov 2010 Location: Indiana Points: 3427 |
According to Norm Swinfords book "AC Farm Equipment 1914-1985".
The B was replaced by the D-10,the CA by the D-12. The D-14 replaced the experimental model CA30,and model 101. Also he said in the book, "that the D-14 had the same power as the WD and it was not quite a three plow tractor".The D-15 with 18% more power replaced the D-14,and the D-17 replaced the WD-45. |
