D14 Thermostat and Operating Temps |
Butch1581 ![]() Bronze Level ![]() Joined: 07 Mar 2021 Location: Hortonville, WI Points: 32 |
![]() ![]() ![]() ![]() ![]() Posted: 19 May 2021 at 9:09am |
I replaced the non functional mechanical thermostat with a new Bosch mechanical thermostat. Thermostat shows the tractor operating at 150-160 pretty consistently now. I know the manual says it should operate between 170 and 220. I'm assuming there must be a 160 degree thermostat installed, but I have not opened it up yet. Is 160 degree thermostat typical on these? Should I swap out to a 180 degree?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21725 |
You'll be fine. Leave it alone.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24573 |
I'm with teh doc... leave well enough alone !!! What you do NOT want to do is replace it with a 180, only to find out the '180' is STILL on the bench, next to the phone you just HAD to answer......
Alright. If it's not a big deal I'll leave it, but thr manual states that it must be at least 170 to avoid condensation build up. What would be the harm in changing to a 180?
Nothing. You don't realize how many THOUSANDS of D-17 gas tractors had 160 degree stats in them.
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
How do you know it's 160 degrees? Gage? Maybe a 60 year old gauge is weak and not reading correct? If it ain't broke, don't try to fix it.
I don't know for a fact it's 160 degree thermostat but I just installed a brand new Bosch temp gauge. My initial thought was that maybe whatever thermostat was in there was stuck open.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7482 |
If the tractor does not get used much or gets used for light duty work, it's good to put a 180 degree Tstat in it so it runs a but warmer. That is what I put in mine. |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 53854 |
My suggestion would be to use an IR thermometer on the block, while the motor is hot. The 149 ci block also had 2 different sensor locations, one up front, at the t-stat, and one near the manifold, that was very close to the exhaust manifold heat bleed. temps at the 2 locations could vary 20-30 degrees...
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1210 |
I put a 180 along with a brand-new temperature gauge in my Model C last summer and frankly I wish I had gone to a 195 (it had no thermostat in it whatsoever when I opened it up). I simply do not use it hard enough for a 195 to ever be a problem here in the moderate climate of northern Idaho. If I lived in a warmer climate and used it for its original design purpose of bona-fide farming pulling a plow, etc. at heavy throttle settings, then a 160 would probably be about ideal. |
Thanks for the replies. I live in Wisconsin and the D14 has a loader on it. We mainly use it in winter/cooler months and use it for moving logs to the sawmill and moving snow and dirt. No field work for sure. Does that change anyone's opinion? I will shoot the block with an IR this weekend. Great idea!
