D14 Rear Axle Bearings
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Topic: D14 Rear Axle Bearings
    Posted: 28 Dec 2018 at 8:07am
Well, I got the axles out of the housings and need to remove the bearing cups to replace the oil seals. Looks like a job for a bearing/gear puller? any thoughts? This is a first for me. Thanks for any suggestions. Bob@allisdowneast
I used to think I was indecisive, but now I'm not sure.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2018 at 6:16am
Good morning Bob,
You mean you need to pull the outer bearing cones from the axles to replace the axle seals don't you? You should be able to drive the cups out of the housing to replace those. Yes, a puller would do it, or the right bearing splitter, supports and a press. You run the risk of damaging the cones either way so you may want a line on new bearings (I have SKF 387AS for the cone and SKF 382 for the cup, SKF 27470 or National 415009 for the seal; may or may not match yours). By the service manual you also should have a "U" shaped plate about 1/4" thick to put between the axle flange and seal when installing the axle. The plate pushes the seal into the bore. Remove it when the seal is flush to the housing then continue assembly.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2018 at 8:15am
Jim, yes, I meant the outer bearing cones. Looks like an opportunity to buy more tools. Thanks for the response and info. Bob
Tireboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tireboy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2018 at 9:08am
Harbor freight has a cheep separator / puller set that will probably work if you don't use it every day. If you want better quality OTC makes a set but you will pay considerably more. Harbor Freight has 25% coupon on the thirty first and the first.
Dave
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2018 at 10:48am
If you are replacing the cup, all you need is arc welder and place a few short beads and it will just about fall out, no puller needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2018 at 12:11pm
Thanks, Dave. Looks like a trip to Harbor Freight on Monday. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2018 at 3:53pm
I have to try that someday! If I remember!
Great tip that could save a lot of work!
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2018 at 4:13pm
If you are replacing the cups I'm with old farmer"s suggestion to use the welder. I have done it many times, to install new ones put them in freezer and then tap in with brass drift.
This page was generated in 0.111 seconds.
