D14 questions
Leadfeather View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadfeather Quote  Post ReplyReply Direct Link To This Post Topic: D14 questions
    Posted: 9 hours 25 minutes ago at 9:26pm
I am considering purchasing a wide front d14 that seems pretty clean but I noticed it has 14-24 industrial tires on the rear. I was not aware this was a tire option in this size. Tire options are limited are there any options for buying wheels and tires from other equipment?I am looking to use this tractor for a preservation / pasture clipping and maybe some garden work. Is there any model specific problems i should look for.   Thanks in advance
Edited by Leadfeather - 9 hours 16 minutes ago at 9:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 28 minutes ago at 10:23pm
Standard "FARM" tires were 12 x 26 diameter.... I dont know about the D14, but many industrial tractors came with 14.9 x 24 tires ... we have that on a CASE backhoe.. Tires are readily available for 24 inch rims.... the 26 are more difficult to find.... you maybe lucked out !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 14 minutes ago at 3:37am
Welcome to the site.Clap
As someone else said, 26" rims were factory.  Used rims/ tires from an older combine will work, but won't be PA rims... Other than the usual fluid leaks, check to see if it slips out of 3rd gear, when it crests a hill, and starts to go downhill...
This page was generated in 0.035 seconds.
