d14 powering down after increased throttle
jsantacroce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jsantacroce Quote  Post ReplyReply Direct Link To This Post Topic: d14 powering down after increased throttle
    Posted: 08 Aug 2012 at 6:31am
I purchased a project '59 d14 last summer and recently the tractor starting shutting down after a few minutes of operation.  It seems to idle fine but anytime I increase the throttle and take it for a ride it shuts down.  I've followed the owners manual suggestions and checked the air filter, cleaned the fuel filter screen and sediment bowl, cleaned the carb checking the float to gasket gap, changed plugs with propper gapping and replaced the 12 volt coil.  My next effort will be changing the points but I'm wondering if someone with more experience than me knows of another thing to check.  I have to admit I'm new to this with no prior experience but I've enjoyed the challenge of fixing the tractor myself.
Protrucker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2012 at 7:23am
So, how much do you want for this tractor......since you posted in the classifieds?
"ALLIS EXPRESS"
Allis Chalmers 1944 B, 1949 B, D14, WC
Post Options Post Options   Thanks (0) Thanks(0)   Quote jsantacroce Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2012 at 5:15pm
I apologize, it's not for sale. I'm new to the forum and posted this to the wrong location.  Any suggestions?
Scott(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 7:28pm
Try removing the sediment bowl and strain your gas and pour it throught the tank a couple times. Check the line from the tank to the carb. Might also disassemble the carb and blow out all the passages. Mine also gets trash behind the seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 7:32pm
Could be something floating around in the tank or a restriction in flow anywhere from the tank to the carb bowl. My CA did that once. Gave me fits till I found the cardboard "gasket" from a clorox bottle that the renter used to put gas in the tractor.
Scott, my truck gets trash behind the seatLOL
Edited by CTuckerNWIL - 09 Aug 2012 at 7:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 7:41pm
Charlie, that's why I got an extended cab; takes longer to fill up. lol
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 8:20pm
I had a D14 do that one time. I cleaned the carb new points plugs and wires. It still did it. it would idle but as soon as I put it under a load it would act like it ran out of gas. I pulled the sediment bowl/shutoff assembly and nothing fell out.I tried the rinse trick and the gas would come out fast then just barely. I got a flashlight and found an acorn in the tank that was to big to fit through the threads and fall out. I finally broke it in pieces and got it out. It would always let gas through but not enough.
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 9:37pm
Put a new condenser in.
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jsantacroce Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 8:09am
Thanks for all of the suggestions.  The gas seems to flow fine from the tank to the filter.  I tested it while I had the sediment bowl and screen off for a cleaning, but I'll get a flashlight and look in the tank just to make sure there isn't a blockage.  I ran air through the fuel line from the fuel filter to the carb and there wasnt any resistance.  I checked the carb, gave it a good cleaning but I didn't replace the gaskets which could have been a mistake.  Since I already replaced the plugs and coil my next plan of attack is: 1) replace the carb gaskets 2) check the condensor 3) check the points.  Hopefully the 14 is back in business this weekend!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 8:16am
The fuel filter could be the problem. Some are made for gravity flow systems, others are for fuel pump systems. The tractors ran fine for 40+ years with a sediment bowl and steel line to the carb without a filter. Rubber fuel lines can cause problems too with ethanol in the gas. The rubber can break down and crumbs will plug small holes in the carb passages.
Edited by CTuckerNWIL - 11 Aug 2012 at 8:17am
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2012 at 10:46am
Dangit... I tried that, and it filled with KIDS... WTH???
Okay, there's clearly more than one possibility here, and I'll second the fuel-flow AND condenser/points/coil possibility... you'll have to prove out each system in order to find out for certain.
Fuel flow IS a high suspect, and I've been in your shoes with it... make sure the WHOLE SYSTEM is totally stock (no filters, no rubber, correct fuel cap, etc), and do a dump-in-can flow test... if it empties a half gallon out of the tank, with cap on, into a jug right out the drain in the carb in under 2 minutes, then you have good flow.  I've had 'em flow like mad for 15 seconds, and then fall flat.  Wrong caps (not vented), sediment and objects blocking the inlet, missing screen, ball-bearing in the sediment bowl, filter with a check valve, rubber hose that collapsed internally, float valves that jam against the body, needle valves that 'marry' to the seat... every one of those things have hexed me.  The absolute, positively worst hex, was when the oil-bath air-cleaner ended up with enough moisture to freeze, and block off the airflow... that one kicked my arse... because I towed it into the shop, let it warm up, pulled and rebuilt the carb... put it back in, drove it to the barn, parked it, and !@#$ if it didn't do it again the next day...
The igntion system... it's hard for it to 'slow' the engine down, however, the lack of a good condenser, or points that have a bad spring, or a coil that's incorrect voltage, or wrong polarity, will do some obnoxious stuff.  Remember that when running slow, the amount of TIME that the contacts are closed, is long... that means, lots of time for magnetic field to build in the secondary.  As you speed up the engine, the amount of closed-time ('dwell') shortens dramatically.  The ignition coil's magnetic properties (inductive reactance) has an effect on how the field builds, and as a result, a small problem inside the coil may result in a runs-but-poorly situation.  Likewise, the ignition coil spring frequently carries electric current for the primary side... if the primary side of the system winds up carrying excess current, for a long enough time, the point spring will overheat, and the metal will anneal (get soft), resulting in very low pressure on the points when closed... this translates to higher resistance, and less current flow through the points to coil primary.  With the points being closed for a longer TIME, there's a higher likelyhood that light contact pressure will NOT hinder development of a spark.  As the engine speed comes up, the points have less dwell time, and of course, with the spring tension being low, the contacts 'bounce'.
The condenser's job, is to cushion the 'jolt' associated with the primary circuit opening and closing each time the point cam lifts the points.  If the condenser is failing, the 'jolt' tends to cause the points to carry an arc after they've opened.  This translates to continued primary current, which means the magnetic field in the coil doesn't collapse properly, hence, spark goes to crap.
Now, much of this can be eliminated through testing.  Start it up, bring it up to 'fall off' speed, and pull the choke out a smidgen... if it recovers, and you can keep it going, it's a fuel flow issue.
If not, points and condenser.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2012 at 11:35am
If you feel your bowl assy. is filling quickly (left loose and gas cap off), it may be still restricted. Gas should run out of the bowl/valve assy. very quickly and over time you may not notice it slowed down.
My D15II acted like it did not have enough fuel while brush cutting recently. Barely made it back and up onto the trailer ramps, but dropping the bowl, it appeared to have plenty of fuel running out of the tank with the bowl off.
Back to the shop and siphoned the fuel from the tank. What was left ran freely when the bowl/valve assy. was unthreaded from the tank, so valve assy. suspected. Passage from valve was nearly completely blocked off with a reddish semi-hard deposit. Cleaned out with a piece of wire and a shot of carb cleaner to blow out any remaining residue before reinstalling on tank. Ran very fast and bowl filled in about 10 seconds, loose with gas cap off and tank nearly full.
Sometimes we don't realize that full flow has been restricted, but she needs everything you can get into the bowl continually to run properly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2012 at 12:42pm
 If choking it helps keep it running, don't waste time looking at the ignition side. It is a fuel flow problem.
Edited by CTuckerNWIL - 12 Aug 2012 at 12:43pm
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2012 at 11:07pm
I'm also thinking you have a fuel flow problem. My guess is something has your high speed jet/needle partially or completely plugged. When at an idle, it is getting fuel from the low speed jet and when you advance the throttle, it cannot get enough and will then quit. I've experienced this with mine once. Try closing your choke when you advance the throttle and see if it will try to keep running. If you can keep it running with the choke, then something is definitely plugged. Good time to put a carb kit in and give it a good cleaning.
just my 2 cents...
Ben
JRaymer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JRaymer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 12:03am
could be dirt dobbers in the air intake pipe.
mherndon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mherndon Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 5:45pm
My D-14 was doing this after a good warm up. It has been doing this for a while. I think I finally found the problem thanks to advice from this forum. My intake had a leak. Not sure where, but bush hogged yesterday after putting new switch on. I thought my problem was electrical. When it warmed up and started cutting out, I knew the switch was not the problem. I looked at the carborator bolts and saw that one of the lock washers was not compressed. I tightened the two carb bolts then went to the intake manifold. I was able to tighten all of these as well. I finished the job and did work the rest of the day. My tractor has never run this well before. I plan on getting a carb kit and a new intake manifold gasket soon.
D-15, Old dealer in Smithville, TN
This page was generated in 0.067 seconds.
