D14 power steer fluid?
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: D14 power steer fluid?
    Posted: 14 Sep 2023 at 6:50am
Once again what shall I use? Thanks!
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 6:56am
sorry, none available,..... you'll have to haul MY new D-14 up here. I need another 'winter project' !!!!!
My D-14 doesn't have POWER STEERING , sniff sniff.
Still smiling ?????
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 7:40am
Keep it simple. Use hydraulic fluid like you probably have a barrel of for the other tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 7:40am
Ha ha J this was supposed to be my winter project also but pretty sure I’ll have it done in a couple days then I’ll be looking for another one lol in the meantime I think automatic transmission fluid
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 11:49am
Thanks Doc I like simple!
                          Dana
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 3:47pm
ATF is you are confident that your seals don't leak.  If not, hydraulic oil will work but is thicker, so ATF works better in cold weather.
I run ATF in both of my power steering models.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 4:27pm
UTF, Hydraulic oil, or Trans fluid.. as long as it is Type F, A or the old Dextron 1 or 2.
I would not use the "NEW" MERCON LV or Dextron V or similar that is HIGH in cleaning addatives.... that could effect seals as DSeries said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 5:07pm
IIRR, Book says use 5w20 ND...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 5:55pm
She doesn’t leak a drop so far and is topped with hyd oil Thanks! Scrubbed dried and taped her today
                          Dana
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 6:02pm
A short history lesson on oils A-C has used: A 1948 model WD used 10W or 20W (temperature sensitive) non-foaming/non-detergent oil in the hydraulic sump. A 1953 WD-45 was the same requirement. A 1957 D-17 stayed with this same oil type in the hydraulic and power steering. The Power Director clutch at this time used 80/90 wt gear oil. Sometime after 1957 the Power Director clutch began to also use a 20W non-detergent oil, same as the hydraulic sump. 1964 was the introduction of the Series 4 D-17. It now had Dexron "Type A" oil in the Power Director clutch/hydraulic system (all one compartment now) and the same type "A" oil in the power steering. Three years later, in 1967 the One-Seventy also stayed with type "A" oil, which by now had been branded Allis-Chalmers 322 Power Fluid and 80/90 in the transmission/differential. By 1969, the oil recomendation now became Power Fluid 821 everywhere (10W30) thus replacing type"A' fluid and 80/90 gear oil. Remember, 821 became 821XL and then, PermaTran. Today's oil is used completely thru the transmission, final drives and hydraulic system on 600+ HP AGCO tractors. There is no manufacturer that goes back and re-writes the owners manual of tractors 10 or 20 or even 60 years old. We just have to figure out what works. 821XL/PermaTran keeps it simple !! One oil serves everything winter and summer !!
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 12:46pm
What would your local source of oil say if you walked in an asked for 10-30 non detergent today. I had a run in with the local Exon distributor back in the early 80's asking for a barrel of it.  I thing I had to show them the operators manual, for the Orchard Machinery Corporation nut shaker. Not a complex hydraulic system by todays standards. A Vickers vane pump 3 cylinders for clamp movement and the for the one for clamping the limb, and 1 motor to do the shaking. And to bring it back to AC mounted on the U frame of a Garwood dozer on a HD 9 crawler.
Edited by Ray54 - 15 Sep 2023 at 12:47pm
snowman(MI) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote snowman(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2023 at 6:51am
Dr. Allis' short lesson on oils should be added to the knowledge section if it isn't already.
1950 WD, 1966 D-10 III, 1961 D-10 II, 1966 D-15 II Gas, A-C Minibike, 917 Hydro Mower, 917 Hydro Blower w/cab, West Michigan "Allis Express"
