D14 issues
ironac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Topic: D14 issues
    Posted: 27 Apr 2012 at 12:08am
On a d14 is there supposed to be 2 springs in the front of the cam? The book shows 2 but Im putting it back together and only have one. I also need a couple head blots. Some of mine are bad. And also is the crank shaft pulley a sweat fit? I tried tapping it on with a rubber mallet but it only makes it about halfway. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 7:52am
I'm looking at the parts book...
1) should be 2 springs. a small one(#5) is the oil relief valve spring.
the other(#9) is called a thrust spring.
2) can't help with head bolts,sorry.
3) pulley should slide on though tight fit. I'd file the inside of the pulley a bit, clean out the keyway,polish the crankshaft too. Add a wee bit of oil to help it 'glide' into final position.
also , be sure to put the clutch release lever on the tranny side of the cast iron boss NOT the engine side !!!! or you'll be splitting your D-14 apart like I did on Sunday.
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 12:46pm
Check for ridges in the keyway.  That old girl has turned one way since I was in high school.  The woodruff key has a tendency to bite into the side of the keyway, making a speedbump that can be hard to get around.
Edited by Dave Richards (WV) - 27 Apr 2012 at 12:47pm
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 9:10pm
I used some heat from a propane torch when I installed my crank pulley. I don't like to file things like that, before you know it the pulley is wobbling. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 11:24pm
Can I buy the spring and head bolts at agco? I might just get some sand paper out and smooth everything out. The stick the pulley in the oven and heat it up. Hopefully it will slide right on
