D14 head gasket questions
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Topic: D14 head gasket questions
    Posted: 08 Jul 2016 at 4:53pm
So my d14 has always smoked since I've bought it. I figured it was valve guides and I'd take care of it this winter. Well I went to use it the other day and I noticed some oil dripping from the top of the radiator. I opened the radiator and the fluid has an oil feel to it and does not look right. The smoke also does not smell like it's just oil burning. It's it possible that the head gasket has going bad? Or what else could be allowing oil and water to mix?
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 4:59pm
Most likely the head gasket. I forgot how you check but the other likely cause is the orings that seal the sleeves to the block. These motors have wet sleeves which means there is a orings on the outside of the sleeve about half way down which separates the oil from the water. The orings can fail simply from age.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 5:02pm
Oh if you pull the head I would recommend replacing the head bolts with with new bolts from arp. I just rebuilt a d15 and the old bolts wouldn't hold torque one ended up snapping off but I was lucky and was able to get it out before it broke in two. I know alot of people reuse these head bolts but figured I would pass along what happened to me recently.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 5:19pm
Thanks Dan. If the o rings fail wouldn't i get antifreeze in the oil pan instead of oil in the radiator?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 5:22pm
Does the oil look milky? I would expect in either case if oil can make it to the coolant system coolant could make it to the oil system through the same leak point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 6:15pm
If the exhaust has the sweet smell of antifreeze in it, then its a pretty good bet that the head gasket is the culprit.  IF you take the head off, its always a good idea, to have the head pressure checked, to make sure it aint cracked, too...
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 7:14pm
The oil does not look milky. That was the first thing I checked. I always have the heads checked for cracks and other blemishes when I have them off. It sounds as if the heads coming off
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 7:18pm
I think others have said if you remove the oil pan first you can check the o rings but I don't know just what you are looking for.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 8:28pm
Check the core plugs under the rocker arms for pin holes. I would check that real close unless you want to do a valve grind with new guides. If that is the case you can check it all out after the head is off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 8:46pm
Take the oil drain plug loose, and stick a paper towel against the plug, if you see AF wicking into the paper towel, you might want to drop the pan.  What you are looking for is AF leaking from the bottoms of the cyl liners.
Sounds like this ain't your first rodeo...
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 8:54pm
Thank you guys. I'll tear into it in the morning. I might pull the pistons and put rings in it while I'm at it because it does burn oil and I'll be in it any ways
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 8:56pm
If you pull the pistions I would do the o rings not that much more work to know you replaced the old rubber or whatever they are parts.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2016 at 10:34pm
There is no way oil can get into coolant from sleeve o rings . It has to come from where oil pressure is near coolant or the bucket you filled radiator with.   MACK
