D14 Engine tick?
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: D14 Engine tick?
    Posted: 18 Jun 2012 at 9:59pm
  I seen a D14 for sale 10 miles from me. Hes asking $1500 OBO but it has an engine tick he said. He said he had the top half worked on but it still has a tick. I dont know what they did to it but what would be below the head that would tick? And what do you think its worth.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2012 at 10:17pm
If it's a tick then it's most likely the valve clearance is a little too loose.  This is harmless.  Even if the head was worked on or even rebuilt you must set the valve clearance after re-installing the head.  Now if it's a knock then that's not good and an engine rebuild will be coming down the road very soon.  I'm no expert but that's my 1.5 cents worth.
If it's a rod knocking then $1000 may be too much.
Edited by Stan IL&TN - 18 Jun 2012 at 10:19pm
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2012 at 7:19am
A tick can be an exhaust leak also. I would think if they worked on the head, they used new a manifold gasket but it could have a small hole or leak in there somewhere.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2012 at 12:06pm
I havent looked at it yet, I was wanting a hundred series tractor but since this one was close I was going to look. Thanks for the tips and Ill see how it goes.
wfmurray View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2012 at 12:18pm
Had one in my 14 . Pulled down twice . It was a oil ring on no 3 that had to much up and down play . Engine had got to hot  , heat guage was bad.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2012 at 1:55pm
If it is a tick, put a tick collar on it or spay it with deet.
Seriously, I bet it is an exhaust leak.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2012 at 5:32pm
Also does it tick all the time, loaded, or un loaded? A tick that goes away under load is worn wrist pin or pins or no lube to them. One way to check for a wrist pin tick is to pull plug wires off while running one at a time. Noise will go away when you kill spark to problem cylinder.
However I agree with most its 98% valve train tick.
