D12 with throw out noise |
krieg1952 ![]() Silver Level ![]() Joined: 07 Nov 2010 Points: 60 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Sep 2012 at 4:11pm |
I have a 1959 D12 that makes a lot of noise at the throw out bearing. Is the throw out bearing servicable or does it have to be replaced? Thanks in advance.
JoeO(CMO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Did you try to grease it?
Edited by JoeO(CMO) - 23 Sep 2012 at 7:47am |
How do I get to it to grease it?
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5899 |
Krieg
I checked in an Allis 'Operators Instructions Manual' for the early D-10 and D-12 and was suprised that there was no mention about lubricating the clutch release bearing. Gary
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Most T/O nearings I have seen are sealed bearings (it is adjacent to the clutch/pressure plate and grease is not compatable with them); believe the D12 has a sealed T/O bearing.
Is the noise constant...or is it noticeable when you depress the clutch? A constant noise indictates a worn T/O bearing; noticeable only when the clutch is depressed indicates a dry or worn pilot bushing/bearing. One needs to split the tractor to service the T/O bearing and/or pilot bushinf/bearing. Sometimes, one can re-grease a T/O bearing similar to regreasing wheel bearings; however, its probably best to replace the T/O bearing seeing as how much is involved to access it, and the cost of a new one is reasonable.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
TimNearFortWorth ![]() Orange Level ![]() ![]() Joined: 12 Dec 2009 Points: 2014 |
Worth noting on the newer units where a perceived throw-out bearing noise had us scratching our heads. Sounded like the throw-out bearing but all had been replaced with new. Turned out we needed to make a new bushing at the rear of the hollow quill shaft as the worn bushing noise travelled forward through the torque tube.
Drove us nuts on a late 1960 D12, equipped with live hydraulics and live PTO.
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10781 |
Aetna offered a greasible throwout bearing for the D series. Use common sense and grease sparingly. HTH Tracy Martin
