D10-D14 rear crankshaft seal retainer
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Topic: D10-D14 rear crankshaft seal retainer
    Posted: 10 Aug 2012 at 10:45am
Well I've e-mailed Illini and Sandylake about price and availability of the above and have not heard back. If anyone out there has one they would like to sell please PM me price and postal cost.
Edited by SteveC(NS) - 10 Aug 2012 at 10:49am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 10:59am
Wouldn't ya know, I just got a reply from Sandylake! I replied asking for an estimate of the USPS mailing cost.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 6:17pm
Cost for shipping was almost as much as the cost of the part. I think I'll be spending some time in the machine shop modifying a CA retainer. If anyone's interested I could photo document the process  .
michel.forest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michel.forest Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 6:42pm
Hi Steve I have one and shipping from Québec prov, will be less expensive. I will check tomorrow and send you the price for the part and shipping.
 thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 7:16pm
I wanna see this. I have a CE engine that needs rebuilt so would be real interested. Might have to do it myself:)
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 6:07am
What was the price  .   If you are outside USA shipping not cheap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 6:37am
Michel, thanks for the response PM me your asking price and postage and I'll send you a cheque or whatever you prefer.
Fred, I'd rather not mention Sandy Lake's price. I noticed a rather lengthy privacy & conditions statement and although I didn't read it all, I figure I'll be discrete.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 5:12pm
We'll , not that anybody was interested, but I finally separated the CA only to find that the ruberized cork crank seal was not to blame. Laugh at me as you wish but I had not torqued the pan bolts enough so it was just seeping from there.
Lots learned by me, some learned by you about me ( tail between legs, hiding in the corner)
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2012 at 2:57pm
The CA is back together, still runs like a charm, unbelievable oil pressure (middle of the guage) and no more oil leaks. Closer inspection had shown some seepage from the oil filter to block casting so I tightened those two bolts also.
The engine seems to have lots of pep, this is the one I milled the head 0.100"  after I installed the reground crank, I think it's gonna serve me well.
Now I'm onto the front mounting of the snowblower.
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2012 at 3:09pm
Sounds like a good deal Steve. Glad is was because you didn't tighten the bolts enoughrather than overtighten them. That can sometimes lead to lifetime oil leaks, especially in that area. Front mount snowblower might take a little headscratching, but we have faith in you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2012 at 7:19pm
That oil filter housing can be a real pan to stop leaks. Someone on here filled the "pockets" on the back side with epoxy so you have a solid surface with more area for the gasket to seal. The die cast housings are prone to twist with over torquing. A few minutes with a file and you can get her back flat again.
