D10-12 seat & steering wheel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: D10-12 seat & steering wheel?
    Posted: 11 Apr 2020 at 10:48pm
Has anyone ever put a deluxe seat on a series 1 D10-12? Did you move battery to same location as the series II and III? Anyone ever raise the height of the steering wheel? Thanks Tracy
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 8:52am
Tracy,
Looking at my parts manuals.
First everything refers to before serial # or after #, instead of D-II or D-III.
The battery box for before and after is different #. The covers are the same.
I can make you a new battery box for the after, series II and III.
I've never considered changing the hight of the steering wheel. I'll have to look at my
D-10 series III, to see if I think it would be practical.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 9:29am
Dusty, I like the little tractors, but my knees are at the steering wheel. It makes shifting gears cumbersome. On my series three with deluxe seat, you can shift it further back because battery is not in way. I thought of making a steering wheel riser of about 2-3 inches, that would help also. Just wondering how many out there feel crowed on that little operator's platform? Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 3:06pm
Just use a "deep Dish" steering wheel from something like an I-40 or 190 ect. That what I did on my D10 puller.
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 3:19pm
The deluxe seat fits on the seat frame that was used on D10's serial number 2266 and up and on D12's serial numbers 2241 and up.  To install the deluxe seat, you would need the later seat frame and would also have to change the battery/seat deck plate as well as moving the battery box.
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 5:21pm
I have a series I steering box with the longer shaft, I need a series III box.  I thought about making it work but I want to keep mine original.  Side plates and throttle linkage is different but it will bolt up.
The universal answer to all questions is yes, how much do you want to spend?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 6:23pm
Paul, what is diameter of the dished wheel? Are they the same splines? Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 6:26pm
Larry, I looked at that as well. I have several seat frames that are good condition. I haven't looked at deck plates close, but at a glance, other than some hyd plumbing needed to move. I figured someone has already done this to have more room. Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 10:06am
Tracy,
I have a G steering wheel for the G, it good use a new covering.
Maybe it could made to be like the one on PaulB's D-10 that he posted a picture of.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 5:19pm
Dusty, I think one off a I40, or an I400 will work. It is dished. I don't know the diameter of one. Without power steering, one much smaller than original would work you over pretty good. Thanks Tracy
