D10 Series 3 Starter/Solenoid Issue
Message Reverse Sort Order
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Topic: D10 Series 3 Starter/Solenoid Issue
    Posted: 15 May 2018 at 7:21am
Solenoid will stick when battery is low. Just needs a new battery.      MACK
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 4:29pm
Things are good in NC, hope you are enjoying the D10.
Jeff K View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff K Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 4:22pm
Verified - Bad Switch.
Thanks Larry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff K Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 3:45pm
That does make sense Larry. The switch might be stuck in the start position. I will get another one.
Thanks,
Jeff
BTW - How's things in NC?  Is everything good?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 2:48pm
Probably a bad switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff K Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 1:44pm
Guys, I have a head scratcher over here in West Michigan. Today I was getting my tractor ready for the first show of the year this coming weekend and when I turned the key it failed to start because it would not turn over strong enough but when I turned the key to the off position it continued to slowly turn over (starter did not disengage) until the battery didn't have enough power to turn it over. This went on for about 30 seconds until I could get the battery cable unhooked. The starter felt warmer than it should but not hot.
The battery is old but I think it has enough juice. I am going to get a new battery anyway but do you guys have any other suggestions or ideas of what this might be? I am thinking solenoid but I am not sure of that.
Thanks,
Jeff
This page was generated in 0.738 seconds.
