D10 hydralics
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: D10 hydralics
    Posted: 30 Mar 2011 at 3:03am
I bought a D10 at auction $1300. Someone replaced the control valve with a log splitter valve. Other than not having a floating position, is this OK??? It has the small constant drive pump on the engine block, looks to be same as a D14 P/S pump, its a little loud and a little weak after the oil gets hot. Are these hard / costly to rebuild??? It also came with a nice 2 bottom plow, now the bad, the whole rig has been painted farmall red!!!!!  thanks keith
EricTn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricTn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 8:33pm
Tractorboy, I sent you a PM.
