D10/12 Series II Voltage Regulator
snowman(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowman(MI) Quote  Post ReplyReply Direct Link To This Post Topic: D10/12 Series II Voltage Regulator
    Posted: 21 May 2018 at 8:41pm
Question, restoring a D10 Series II tractor which had been converted to an alternator with the wiring and such.  I have purchased a new wiring harness but am at a lose for where the original voltage regulator was mounted on the tractor.  I have a Series III which has the voltage regulator mounted on a plate under the generator.  I have a rebuild generator ready to go, but would like to mount the voltage regulator in the "correct" location.  Anybody able to supply / share any pictures from a Series II model.
Thanks,
snowman(MI)
1950 WD, 1966 D-10 III, 1961 D-10 II, 1966 D-15 II Gas, A-C Minibike, 917 Hydro Mower, 917 Hydro Blower w/cab, West Michigan "Allis Express"
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 10:10pm
I hope this helps. I've got the book and I can't tell what its attached to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowman(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2018 at 3:25pm
Thank you, I will start looking in that area as to where the original was mounted.
snowman(MI)
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2018 at 4:32pm
The regulator bolts to the rear gas tank mount.
Edited by Larry in NC - 22 May 2018 at 4:33pm
