D 262 / D-15D |
SIMPLICITY ![]() Orange Level ![]() ![]() Joined: 19 Sep 2009 Location: ERATH LOUISIANA Points: 509 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Apr 2012 at 11:36am |
HELLO
AN ANYONE GIVE ME THE DEGREE TIMING ON THE INJECTOR PUMP I KNOW IT IS BEFORE TDC I JUST DON'T KNOW THE NUMBER OF DEGREES. THANKS THAD |
DonDittmar ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2516 |
If its a d262 then it depends on the model of pump
if its a D175 in a D15D then I am not sure....
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
D-17_Dave ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
My service book shows 2 models of pumps on a D-15, both take 22 degree's static timing on the pump. Also, each hash mark is 2 pump degree's or 4 engine degree's. So keep that in mind.
Also as stated above, the 262 engine is a 6 cyl. for D-17/D-19's. The D-15 uses a 175CI engine with 4 cyl. The 175 engine is basicly a 262 with only 4 cyl's.
Yea, I can fix that.....
