cylinder bar replacement.. when? |
rossinmich ![]() Bronze Level ![]() Joined: 12 Sep 2009 Location: West Michigan Points: 187 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Jun 2015 at 7:07pm |
Having never replaced cylinder/rasp bars or held/seen new ones, what should I look for to tell or know when to replace them? Silly question, but I am relatively new to these combines.
j.w.freck ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
we replaced ours when we had the 66,when the rubber was eroding away from the leading edge of the bars.and wearing down on the rest of the bar.....
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8635 |
Gleaners? If you look down the length of a new one,they have a high point down the center of the rasp and a rather square corner at the leading/trailing edge.When the leading edge gets rounded off they say they wont grab and pull material through.I'll say that the peak down the center is just as important for pinching and pulling stuff through as well.When the top is rounded off and the leading edge is rounded off you'll have a difficult time getting it to take anything through although they still don't do too bad in corn. Soybeans,forget it!A little hard surface on top of a rounded leading edge and a short bead across the center of the peak will help a lot.
