cultivator blight
Dean(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean(IA) Quote  Post ReplyReply Direct Link To This Post Topic: cultivator blight
    Posted: 31 Oct 2020 at 9:18pm
I had never heard the term, 'cultivator blight" which referred to plowing out hills of
corn, until the last few years. Cultivating corn cross ways after it had been
planted with a check wire was pretty apt to result in cultivator blight.
   On an earlier thread, plowing corn (cultivating) was discussed. In Fayette
County, Iowa , when I was young, we called it plowing corn. Must be a midwest
thing.Smile
Dean(IA)
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2020 at 11:44pm
That or "iron worm"...cross cultivating checked corn shouldn't be a problem...dad never said anything negative about it. It was known as "plowing" here too.
Edited by SteveM C/IL - 31 Oct 2020 at 11:45pm
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2020 at 12:40am
My opinion is both of you are correct; in hillier ground (neIA) pull type cultivators will slide downhill several inches resulting in uprooting of corn or other row crop; does not occur in flatter grounds (Shelbyville, IL).  Cultivator was the implement name in central KS. Our two row horse drawn cultivator was horse drawn; Dad converted it to tractor drawn. The operator siting behind the cultivator pushed on foot pedals to turn the two large cultivator wheels a few inches to the left or right.
 In central KS an implement with many disc blades was called a disc. Here in nGA such implement is called a harrow or disc harrow.   Herb(GA)
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2020 at 7:19am
We now call them topsoil eliminators!
  But in the early days, not many options besides them, excisted!
AC from the start of my families farming career till the end!
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2020 at 8:42am
WE used a Spike Harrow to break  up hard crust ground just as corn was coming up .
nonetheless ,still dead.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2020 at 1:20pm
In my family (Central Nebraska) cultivator blight is an operator error, not a gravity issue Wink
Still in use:
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2020 at 11:49pm
In southern IA we plowed corn too. My grandpa from northern IA always called it cultivating corn. He retired from farming and always came down to help plant and cultivate.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2020 at 6:55am
Interesting. Central IL “old terms” (1960-1980s)
“Row cultivating” was our term used to describe corn or soybean seedling rows being cultivated. You’d consider it good to do 1 pass thru corn & 2 passes thru soybeans. Problem fields like weedy soybeans would also get walked to cut out weeds with a weed hook or hand pull weeds.
”Field cultivating” was our term for field tillage before planting crops.
Edited by AC7060IL - 04 Nov 2020 at 6:59am
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2020 at 9:10am
We cultivated corn up through the 80's. My Grandpa used to come up and stay a few weeks in the summer and he did most of it. Had JD 40 and mounted 2 row cultivator.
When he got too old to do it anymore, Dad bought a 3 pt. 4 row unit. I remember my first time cultivating at about age 14, dad never showed me a thing, just said you lower it to the ground and go and watch what you're doing, pretty straight forward.
OK.
So off I go, did good, then I'd be pulling out corn, and I'd adjust, and then be OK, then pulling out corn, I'd go up and adjust, had a heck of a time. What really had me puzzled was Dad had said everything should be good to go adjustment wise. He came home from work and I was up at the shop adjusting again, obviously more than a little frustrated. He probably saw all the dug up corn on the way home from work too, probably not real happy!
That's when I learned that the outside shovel goes back down the same row when you turn around!!! Oops.
Edited by Tbone95 - 04 Nov 2020 at 9:11am
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2020 at 11:08am
Same terminology where I grew up...
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2020 at 8:58pm
Since a tike it’s been cultivating corn never heard the term plowing corn till year or so ago on Agtalk.
If I’m cultivating anything someone better be paying me a premium.  Cultivated green beans and sunflowers.  We no till a chunk of our corn so it’s not feasible.  Besides to much root pruning and stirring it again just germinates more weed seed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2020 at 4:01am
i always told dad that lightening must have struck there!
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2020 at 6:56am
My job in my early teens was cultivating (called scuffling in Canada) corn with a mid mount two row on a D 14. Blight was common when I couldn't keep my eyes open.
Years later I started growing dark red kidney beans which required building a hill on the row so the plant could be knife cut (pulled) at harvest. Usually took two passes. My machine was a D-19 with a 6 row rear mount. Worked well but had to install 14.9 x 38" rears for the second pass. A D-17 IV diesel arrived and now I used half as much fuel. The problem was that on a  D-17 the front wheel spacing was either 58" or 62" which was a problem when the planter wheels were spaced 60". The solution was D-19 front wheels or finally wheels from a Gleaner A both with a different offset to get 60". Eliminated a lot of cultivator blight!  Rears were changed to 14.9 x 38". Gets a little boring after 250 acres with two passes per year but we were usually well paid at harvest.
