Cracks in a D17 diesel head
danraley88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote danraley88 Quote  Post ReplyReply Direct Link To This Post Topic: Cracks in a D17 diesel head
    Posted: 13 May 2017 at 7:48am
I have a D17 diesel head with hair line cracks at the hole at the end of the injector tip. Can this be fixed or does it need to be fixed. Thanks for any help.
1945 WC, 1948 G, 1950 WD, 1956 WD45D 1959 D10,1966 D12, D15 Series II, 1959 D17D, 1959 D17, 1964 D17 Series IV, 1971 185
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 10:15am
some one will know but I think on those ,as long as cracks don't go to valve seat you are ok.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 12:51pm
Pressure test the head; if the crack(s) don't leak you can repair the cracks ("stake" them?) and/or use the head. Be sure to allow the engine to cool down after running before stopping the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote danraley88 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 5:55am
Thanks I will have the head pressure tested and see what happens. This tractor is new to me and was in boxes when I bought it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 8:48am
Check your sleeve standout. They were known for the sleeves sinking in the block and blowing the gasket. If the sleeves are low, you really need to fix that or you're going to have trouble holding a head gasket.
This page was generated in 0.073 seconds.
