couple b questions |
Glockhead SWMI ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: South West Mich Points: 2657 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Feb 2012 at 11:37am |
My new to me b has stamped on it a number different than my c and ca. The engine number starts with RI. What does this designate?
Also, I have some pretty sloppy steering. Some in the box, some in the tie rods and some in the spindals and bushings. I know where to get most of the repair parts but who has the rebuild kits for the box and tie rod parts? |
MNLonnie ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Baxter MN Points: 4791 |
What is the entire engine #. Could be R1##### which would have been a power unit motor.
looks like r1. I'm going to get it out of the shed tomorrow or Sunday and take a closer look. Are all the power unit engines the same?
According to one book the power unit motors had R or CR or the standard CE prefix, all 125 CI motors.
Thanks lonnie. Seems pretty strong running. Can't wait to get my hands on it this weekend and take a real good look at her.
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Depending what the power unit came off of it may have a shorter govenor spring to give you more RPM. I have 2 tractors with power unit motors on them. 1 is the normal CE set up but the other one , from a combine, has a shorter spring on it and really moves on the road. Bob
AJ ![]() Orange Level ![]() Joined: 31 Oct 2010 Location: mo Points: 5244 |
How does these engine springs and what not make that much of difference exactly?
Can't fix stupid
The springs are on the govenor and control the RPM. Bob
The way I understand it is that the shorter/stronger governor spring just pulls more on the throttle to give you more rpms and in turn more horse power. The CA was rated at 150 higher rpms than the B/C's. Not sure about the power units.
So can u just put a better spring on a c engine to get more power out of it?
Can't fix stupid
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6069 |
Essentially. It's not a 'better' spring... it's a DIFFERENT spring. The governor isn't a complicated gadget- do some reading-up on them, and it'll be much easier to understand.
Horsepower = force x distance x time, so if you have an engine that can develop 130 foot-pounds of torque at 1200rpm, and you increase it to 1400rpm, and it STILL develops 130 foot-pounds of torque, you've increased horsepower. Torque(ft lbs) = HP x 5252 rpm or solved for HP: HP = RPM x Torque (ft lbs) 5252 So in the case of the first: 130 ft-lbs @ 1200rpm = 29.7hp And the second: 130 ft-lbs @ 1200rpm = 34.6hp And here's an interesting catch: If you spun the engine substantially faster, but with reduced torque: 95 ft-lbs @ 2100rpm = 37.98hp Or even faster yet 42 ft-lbs @ 7500rpm = 59.97hp But the reality of physics, is that working for a given horsepower number does not necessarily mean that the tractive effort results (drawbar horsepower) will agree, nor will PTO loading tests reflect the difference in a useful way. |
So torque would be your main focus if your trying to get more power? Because torque is what actually moves the tractor right?
Can't fix stupid
Protrucker ![]() Orange Level ![]() ![]() Joined: 25 Apr 2011 Location: Broome Cnty,NY Points: 718 |
Where does the number 5252 come from?
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87864 |
5252 is a constant that never changes... kind of like PI = 3.14 when you figure the diameter of a circle.. And Dave is right, you want more torque, or the same torque at more RPM.. A dyno measures twist on a shaft or "torque" and then it multiplies by the rpm and constat to get the HP.. HP is just a calculated number.
Edited by steve(ill) - 18 Feb 2012 at 9:12am |
I realize that it's a constant, but was wondering what it based on.
5252 is attributed to the ability of an 18th century English mining pony to pull a rope.
One mechanical horsepower equates to 33,000 foot pounds of work per minute... That is, the ability to raise one pound of weight, 33,000 feet, in one minute... or lift a 33,000lb weight one foot, in one minute... Or a 550lb weight one foot, in one second... which certainly doesn't immediately identify where the magic number 5252 comes from, but... Take a wrench with a handle one foot long, and pull on it with a force of 525 pounds... and you have the equivalent torque of 525 foot pounds. If you can spin that wrench for about a sixth of a rotation, in one second, you'll have proven yourself worthy of producing one horsepower. Why a sixth of a turn? Well, you're turning a wrench that is one foot long... that means the DIAMETER of an equivalent drum is 24" across, which has a CIRCUMFERENCE of about 75 inches. A 75" drum will lift that weight SIX FEET in one rotation. How's this relate to 33,000 foot pounds? Take 5250 and multiply it by SIX. A 2' diameter drum, spinning at 5250rpm, will pull 33,000 feet of rope in one minute... (And for purists, the reason why the math doesn't come out exact, is simply because I truncated the decimal places.) and with one foot-pound of torque applied to the drum, you'll have one horsepower. Here's the detailed math: Drum with 12" radius = 24" diameter, or (24Xpi) = 75.398223686155037723103441198708 circumference or divided by 12 inches = 6.283185307179586476925286766559 feet. 6.283185307179586476925286766559 * 5250 = 32986.722862692829003857755524435 Plus or minus a little because the math was done on a binary computer Powered By A Battery, but running mathematical process on an INTEL processor, running Microsoft Calculator. But I digress... It all comes back to an English mining pony... and a guy named James. |
Aren't you glad you asked?
Work through each of the problems on page 217, and then discuss the ramifications of comparing the performance of 18th century English mining ponies against newly invented walking-beam steam engines. There WILL be a quiz on Monday. |
"Power" is subjective, and without a very clear definition of what goal one is trying to reach, modifications for 'more power' won't necessarily result in the goal. On industrial engines (stationary), the power ratings imply things WAY beyond pulling that rope. See, James Watt was developing a steam engine, and it had a pretty big bore, and a pretty big stroke, and although it couldn't spin really fast, it could pull the rope across a large drum, and it could run a pump to keep the mine from flooding. Imagine the amount of force that a 6" piston can exert when 100psi of steam is applied... pretty simple, really- calculate the area of the piston (6" diameter = 3" radius, and Area = Radius x Radius x pi), so we're talking about a little over 28 square inches of piston surface. With 100 pound of pressure against 28 square inches, you've got 2800lbs of linear thrust. If that piston is pushing on a crank that is 1' from center to throw, you'll be getting 2800 foot-pounds of torque. (Extra credit Question 1: If a steam engine generates 2800 foot-pounds of torque, ABOUT how many rotations per minute does it take to replace ONE English mining pony??) (Extra credit Question 2; If that steam engine turns at 400rpm, how many English mining ponies can it replace?) |
To get from pound-feet of torque to horsepower, you need to go through a few conversions. The number 5,252 is the result of lumping several different conversion factors together into one number. First, 1 horsepower is defined as 550 foot-pounds per second (read How Horsepower Works to find out how they got that number). The units of torque are pound-feet. So to get from torque to horsepower, you need the "per second" term. You get that by multiplying the torque by the engine speed. But engine speed is normally referred to in revolutions per minute (RPM). Since we want a "per second," we need to convert RPMs to "something per second." The seconds are easy -- we just divide by 60 to get from minutes to seconds. Now what we need is a dimensionless unit for revolutions: a radian. A radian is actually a ratio of the length of an arc divided by the length of a radius, so the units of length cancel out and you're left with a dimensionless measure. You can think of a revolution as a measurement of an angle. One revolution is 360 degrees of a circle. Since the circumference of a circle is (2 x pi x radius), there are 2-pi radians in a revolution. To convert revolutions per minute to radians per second, you multiply RPM by (2-pi/60), which equals 0.10472 radians per second. This gives us the "per second" we need to calculate horsepower. Let's put this all together. We need to get to horsepower, which is 550 foot-pounds per second, using torque (pound-feet) and engine speed (RPM). If we divide the 550 foot-pounds by the 0.10472 radians per second (engine speed), we get 550/0.10472, which equals 5,252. So if you multiply torque (in pound-feet) by engine speed (in RPM) and divide the product by 5,252, RPM is converted to "radians per second" and you can get from torque to horsepower -- from "pound-feet" to "foot-pounds per second." Edited by steve(ill) - 18 Feb 2012 at 12:50pm |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Now take a C engine that has been running with the same internal components for 25 years, add a heavier shorter governor spring, crank it up and expect way less horse power when the engine locks up because the rings slammed into the ridges at the top of the cylinders and broke up causing a malfunction. That may be like trying to enter a 18th century English mining pony in the Kentucky Derby and expecting it to be alive at the end of the race.
Okay, so we've determined how much force the engine can produce, and based on a given stroke, we've determined a potential power output...
But there's a catch. In running, that piston DISPLACES 12" of cylinder travel and 28 square inches of surface... that's 28" x 12" = 336 cubic inches of volume. If the steam supply chest has an internal volume of TWO CUBIC Feet, and is full of nothing but steam at 100psi... How many CYCLES can the steam engine go through before it's crankshaft force drops off? The short answer is: Without additional steam input, the input will deplete by a certain percentage at each stroke... which means at each stroke, the amount of torque will fall off... Now, I could go through all the depletion math, but I think I've described it enough so that everybody gets the picture- the boiler's output is critical to performance of the engine... it MUST be able to HEAT water to 327F in order to generate 100psi we assumed above, and it MUST be able to do it at a VOLUME suitable to feed the SPEED at which the engine will be rotating. Just to give you an idea (but we're not discussing this portion today) is the existance of a rating called BOILER HORSEPOWER. Boiler Horsepower defines the limit of a boiler, which is directly related to the limit of ANYTHING that the boiler is powering- be it a reciprocating piston engine, a turbine, or even just a baseboard heater. By the way- one boiler HP= The ability to evaporate 34.5lbs of water into steam at ambient (212) pressure= 33475 Btu/h. And... by the way... one BTU (British Thermal Unit) is the amount of thermal energy required to raise one pound of water, by one degree F. The point here, is that there's much, much more to the picture than just bore, stroke, and RPM. |
In a stationary and agricultural environment, there's much more than foot-pounds and RPM. As Charlie notes, an English mining pony wouldn't last too long in the Ky Derby (but it'd be fun to put 'em in a pen together- that mining pony would bite the Derby horse like a piranha in a toilet bowl full of hamburger)... nor would the Derby winner fare well pulling a mining rope.
But the point being... developing numeric horsepower under one set of parameters, doesn't mean it'll be worth a crap under others. I can easily prove to you that A well-worn 60-year-old WC engine will outpull a freshly-built hard-block'd 2000hp supercharged nitromethane engine any day of the week... By putting it out in a 40-acre field for three hours. The hotrod motor will melt before making a turn at the first fencerow. And finally, it doesn't matter how much horsepower you have under the hood, the limiting factors of TRACTIVE EFFORT, are the diameter of the driven wheels, the amount of drag imposed by all wheels, and the amount of weight applied to driven wheels. Basically, you can simplify Agricultural Tractive Effort (aka 'drawbar horsepower') to being limited by weight, tire diameter, and drag... and once you've reached the effort threshold (where wheel 'slip' exceeds about 6%, that the amount of input horsepower required to pull harder, goes up by a very large ratio... hence, pulling efficiency under wheelspin becomes incredibly inefficient. Power development, and converting it to tractable power, are two totally different things. If you're looking to pull a plow that rolls your soil best at 3mph, and your tractor spins wheels, you'll need to either lose drag, or increase tractive effort by adding weight or increasing tire diameter. Reducing drag means either changing tire size on non-driven wheels, or increasing tire diameter. If you increase tire diameter, you'll have to reduce engine speed to stay at 3mph. If you increase governed speed to increase engine horsepower, you'll have to change gear ratios to maintain your 3mph ground speed. Managing and optimizing drawbar horsepower, as a result, has very little do do with engine horsepower... it's about balancing the draft load, against the tractor's weight and drag characteristics, against the soil's type and conditions, and finally... being able to do it for a continuous length of time under wide ambient and other variable conditions, including, but not limited to hot days vs. cold days, high and low humidity, dusty conditions, low quality fuel, fuel contamination, and all sorts of other little things. But remember- it's a FARM TRACTOR. It was built to be a farm working machine for everything from heavy tillage to operating elevators and augers, cutting and baling, and things that the original engineers could have never envisioned. In order to 'tailor' it to suit a specific need, SOMETHING will have to be given up... and when doing such tailoring, it's good to have a VERY clear concept of what one is attempting to achieve, and realize that in ANY change, there will be a consequence. |
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
After all the technical booklets typed and you decide you are going to pull your C with a stronger spring with more HP you will be disappointed. The stronger spring will give you more HP if you are plowing or fitting ground where you can maintain the higher RPM's.
If you are pulling a transfer sled the load will start to pull down the RPM's. When your RPM's drop to where it was with the original spring you are back to the original HP. You have to be able to hold the higher RPM's under load. The only way to get a real increase in HP is to increase the cubic inch displacement. |
In terms of drawbar effort, that's exactly right. The engine governor limits only the upper RPM limit, nothing more. The 'horsepower' figure of a higher governed RPM is useless when the engine's torque limit is found at a lower RPM.
The only way to take advantage of the higher calculated horsepower of a faster-spinning engine, is to use lower gear ratios, and if you can't find the appropriate ratios to allow the engine to stay at that speed, (or you can't keep the tire slip ratio low enough by virtue of weight/balance/tire diameter) there'll be absolutely no benefit. The biggest failure many make, is to try and modify the engine to produce a 'peak' - a point in the powerband where tuning circumstances cause the engine to develop high amounts of torque at a given RPM range. This is great for a sportscar or motorcycle, but when applied to a drawbar implement, becomes an incredible hinderance, because as soon as the torque required to continue the pull rises above engine's available torque, it pulls the engine off the 'peak', and you're done. Pointless to have a 'peaky' engine in a farm field- better to have a 'flat' torque curve, or better yet, one that generates more torque as the RPMs fall, so that when a high-load portion of the field is in the plowshare, the engine's speed may come down a bit, but the available torque comes up. Can't remember what engine it was, but I was working on a big natural-gas fired beastie many years ago, and it was horsepower-rated for it's max goverened RPM (wanna say 1200, as I think it was driving a 480v generator), but after looking at the engine's torque ratings, it had almost twice as much torque available at 100rpm BELOW it's low-idle point. Edited by DaveKamp - 18 Feb 2012 at 3:05pm |
Yes!
This kind of stuff is always interesting to me. I went to college for mechanical engineering, but that was way too many years ago & I don't work in that field any more.
Thanks for the very informative answer.
Answers to Extra Credit questions:
1) about 12rpm 2) 33 ponies |
