Cork Gaskets
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Topic: Cork Gaskets
    Posted: 05 Aug 2012 at 9:43pm
I have a number of cork gaskets for the final drive pan on a "C". They are old and over the years they have shrunk and no longer fit. Is there anything I can do to get them to expand?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 9:59pm
Put them in a shallow pan of steaming water. It might sound stupid (that's what I thought anyway) but it will soften them up. I had NOS valve cover gaskets for a 318, 65 Dodge Dartand they worked great after steaming.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 10:28pm
I've used that same trick to get old "shrunk cork gaskets soft and back to size.  Even floating them in a pan of very hot water will work. For large ones, I've even soaked them in very hot water in the bath tub when no one was looking!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 10:38pm
LOL No one was looking but did you clean up like a CIS investigator to keep from getting found out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 10:45pm
Oh, Yah!!Wink
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 10:53pm
Always did that back in the 50/60 with cork gaskets , soak and install . Transmission pan gaskets were bad for shrinking and that was before they added neoprene to the cork like many valve cover gaskets did later.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 6:52am
Phil
I have heard of the little yellow rubber duckies in the bath tub, but never cork gaskets.  Tongue
Ummm, not too sure about your habits lol.
