coolant filter
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Topic: coolant filter
    Posted: 24 May 2017 at 1:00am
Head scratchier.  200 filter.  Not sure what they were trying to accomplish.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 3:41am
that's funny right there! prolly had it worked on at a green dealership?
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 5:00am
That's one heck of a puzzle!
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 5:16am
It's called a bypass filter. It allows the water to bypass everything. :)
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 6:05am
Well at least they were changing the filter regularly!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 6:57am
Another good reason to just use treated antifreeze instead of a coolant filter.
ocharry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 9:14am
so what are we accomplishing here??? there are no valves to make the water flow through the filter,,,i doubt it even gets water through it,,,,the lines bypass it,,,,lol,,,,i aint seeing it
ocharry
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 11:27am
looks to me like an employee doing exactly what his boss said-( Boss says: Bubba put one of them there coolant filters on that 200 and make sure its easy to get to! Bubba says: Yes Sir. Just the way I look at things. Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 11:51am
ocharry
I would say exactly nothing.  In fact worse than no filter.  The lines are hooked to
opposing pressure.  Would think it may work some when the cab heated is on. But when it is off, the pressure is reversed and flush the filter contents back into the
system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 11:57am
 Thanks for the vote of support. Is the NAPA Prestone Command SCA what others have mentioned?  Or your preference?  Thanks....Dale
Edited by orangereborn - 24 May 2017 at 11:58am
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 12:00pm
One thing about it , change filter and all the anti freeze is going to run out with no shut offs
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 12:10pm
I use Caterpillar coolant now. I'm sure Cummins has similar and others as well. I started using Nalcool 2000 back in 1976 and have never had a sleeve pitting issue or O-ring failure since as long as the coolant was treated correctly. We told Customers to change coolant every 2 yrs and use distilled water + good antifreeze + Nalcool 2000.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 7:06pm
Wow I'm a shadetree mechanic, but dayum I can do a lot better than that bs
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 10:30pm
Cat,Cummins,Shell all got their names on 5yr-500000 mile premix
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2017 at 3:30pm
Coolant filters are still a good way to go even with good coolant. You would not believe the crap we are seeing in the new diesel engines in the coolant filters most notably the Mack engines. After changing the coolant filters once or twice they are running clean. Initially they are full of grey sludge - from some sort of building process or whatever???? Mack of course denies there is a problem!! LOL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2017 at 7:23am
.....nothing to see here!!........
