converting R style head to fit L2
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Topic: converting R style head to fit L2
    Posted: 30 Nov 2011 at 5:08pm
I've found a 20' flex head close but it's off an R series combine.  I have and L2.  Has anyone on here converted one.  I know it's been done before.  I was just wondering what all had to be done.  I know the R style was off set, will it still be off set once converted?
thanks in advance
Derek
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 9:09pm
I went through that thought process not long ago.  After a lot of measuring and figuring, I finally gave up the idea.  The thing that I wasnt able to figure out how to overcome is the height.  The width can be dealt with fairly easily, the hook-ups, wiring, and plumbing can be adapted, but the height of the hole, (and most of the back of the header if I remember right) is something like 8" shorter on the Rs than on the LMs.  I figured if I went to the effort to make everything else fit, I would still probably have a mess with feeding.  I might be wrong, but if I were you, I would start thinking about how to overcome that first, because the rest seems pretty straightforward.  That being said, if you figure out how to do it, let me know!  I have a nice 324 flex head for an N/R that I bought to try to put on an L2!
This page was generated in 0.088 seconds.
