converting belly mower
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Topic: converting belly mower
    Posted: 09 Aug 2017 at 11:49am
I've got a NFE WD that I'd like to cram a belly mower on. I've run across a Woods 60" that came off a B. Here's the Craigslist link. https://huntsville.craigslist.org/grd/d/reduced-woods-belly-mower-60/6246211409.html
any idea how to make this work?
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 12:13pm
You might want to go to the Woods web site.  They may have made a mounting kit for the WD and might still have some available.
Frankly, I do not recall any mountings made for the WD however, it is worth a look.  They may have pictures of a mounting that may help you.
Good Luck!
Bill Long
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 12:22pm
I would look for one that was made to have the drive pulley on the PTO shaft instead of a B/C type that runs off the belt pulley due to the idlers for the belt being different.  The B/C type are left hand rotation while the PTO shaft type are right hand,, must be a reason for it.
Lance/SC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lance/SC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 1:11pm
HMM---------do I need to go check and see if the  one took off my B when it spun a bearing is still in the shop?          LOL  Ya been to South Carolina lately?
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2017 at 5:05pm
The woods mounting kit for a WD includes a v-belt pulley that goes on the PTO shaft. ive only seen a L306 mounted on a WD. A 60" mower is to narrow for a WD. A finish mower is one place where more power dosent make it better. itll only clear discharge so fast more power just means your going to break it before it stalls and those long belts a expensive.
This page was generated in 0.067 seconds.
